noise floor w/ and w/o input signal
Old 4th September 2006, 07:47 AM   #1
gearheadgene is offline gearheadgene  United States
gearheadgene's Avatar
Default noise floor w/ and w/o input signal
Just wondering how these amps work in real life. At the moment, I am simulating them to get an understanding. Anyway, during simulation with 0V input the noise floor is real flat around -120 dBV (up to around the switching freqency). But, change the input to something real, say 2khz tone, the noise floor jumps up drastically to around - 50dBV.
Is it my simulation, and maybe I am missing something, or do Class D amps behave this way in real life?
Oh, at the moment, the simulation is using all ideal components and no feedback.
Old 4th September 2006, 10:27 AM   #2
classd4sure is offline classd4sure  Canada
Account Disabled
noise floor w/ and w/o input signal Send a message via AIM to classd4sure Send a message via MSN to classd4sure
You mentioned the test frequency, but neglected everything else like gain, power level, type of amp (self oscillating etc)
At higher power the noise floor might increase slightly, but I don't think it's any kind the sort of offender a class B amp would be.
Possibly due to increased EMI, especially with a bad layout. More likely due to parasitics being worked a little harder at higher power levels, which is what a simulator might actually be showing. In reality your filter inductor /core material would play a major roll in how it changes with power levels.
Either way on an extremely dynamic recording with a good D amp, you can crank the volume right up and the noise floor you end up hearing is still that of the recording itself. So that of the amp must be a good measure lower than the majority of recordings out there.
Old 4th September 2006, 11:01 AM   #3
I left out the details because I was really just looking for a real world comparison vs simulation. Since you ask:
1. not self oscillating, 400Khz triangle wave feeds comparator.
2. Open loop. No feedback until I understand this portion of the design.
3. All components are "ideal".
4. Both 1/2 bridge and full BTL topologies.
Can you tell me how much of the switching noise leaks out to the speaker? This test circuit isn't optimized by any means, but with no audio input, the amplitude of the switching noise (at the speaker) is around 0.5 Vp-p. Seems high to me, but I have no point of reference.
Old 4th September 2006, 11:10 AM   #4
Account Disabled
.5V pk-pk is great.
That would be the switching noise leaking out to the speaker there. It should also be at fairly low power.
The speaker's impedance at that frequency is high, time constant of it is long, there's no physical way the speaker can react to it at all, anymore than you could hear it if it did.
The biggest problem of that high frequency ripple is EMI from the speaker wires. If you have long speaker wires or just want to attenuate that ripple even further to help prevent EMI you can simply employ a common mode choke on the speaker outputs.
Some of the older threads in this forum really cover alot of material, even if they're kind of long, worth reading, should help in your quest alot.
Old 4th September 2006, 02:18 PM   #5
.5V pp is good, eh? Well that's good to hear (so to speak)! Again, it's in simulation with ideal components.
how would a common mode choke work in a single-ended app (half bridge)? If I use an L-C filter with more poles, that should help for single ended.
I will look through those posts - thanks.
gene
Old 4th September 2006, 02:24 PM   #6
Account Disabled
Single ended still has a ground return from the speaker. So you just use the two speaker wires, power out and ground.
Old 4th September 2006, 08:11 PM   #7
Pafi is offline Pafi  Hungary
With ideal elements you can't get -50 dB noise floor at 2/400 kHz. There must be some simulation mistake. But for a more or less proper noise floor result you must simulate it with ~100 ps time step! (And this allows only ~-120 dB noise floor with 1024 points FFT.)
Old 5th September 2006, 09:20 AM   #8
my time step is set at {.001/16384}, or around 62ns. which works really well for single tones. I will try 100ps, but you are going to make my 600MHz cpu work hard
Old 5th September 2006, 09:26 AM   #9
ok, but I don't think it will attenuate the residual switching noise because it's not common mode. The choke will help with common mode stuff though.
Old 5th September 2006, 09:28 AM   #10
Account Disabled
with your usual length of speaker wire much of it will become common mode
noise floor w/ and w/o input signalHide this!Advertise here!
What makes an amplifier have a lower noise floor? pjpoes Solid State 28 21st October 2017 09:36 PM
CS4272 noise floor problem 2sb18 Digital Source 1 1st October 2007 08:52 PM
Noise floor rise on heathkit W4-AMs when power supply transformers were swapped terminatorx Tubes / Valves 4 8th October 2006 01:31 AM
noise floor problem johndiy Solid State 12 31st August 2006 01:32 AM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
