Go Back   Home > Forums > Amplifiers > Class D
Old 20th September 2006, 01:38 AM   #81
Originally posted by BWRX
Well, if there's a DC-DC converter involved then those specs could certainly be possible. I just took the "powered by 14.4V" statement as the actual rail voltage for the electronics.
Thanks for clearing that up. 27.5W sounds much more reasonable although that's still higher than it would actually be for an unclipped sine wave and a 4 ohm load. That 27.5Wrms figure is probably at 10% distortion.
This is driving a 2 ohm load. Most of our amps drive 2 ohm loads except for our Mark Levinson amps, they drive 8/6 ohm loads and these amps are 16/12/10 channel amps that output 50 Wrms @ .01% THD+N. These have a patiented switch mode power supply to generate the rails.
Old 20th September 2006, 03:37 PM   #82
FastEddy's Avatar
Default patented switcher supply ?
" ... These have a patiented switch mode power supply to generate the rails. ..."
Curious to see the schematic for this ... or at least a drawing / picture / spec sheet ... Got a link?
Old 20th September 2006, 04:21 PM   #83
Here's the patent: 5,598,325 ??
There're thousands of SMPS patents.
Koolkid
Old 20th September 2006, 04:27 PM   #84
Default Re: patented switcher supply ?
unfortunatly I can't post a schematic and there really isn't any datasheet or specs on the amps them selves since they are an OEM amp. You can find them in Lexus cars here is a link to the car that has the amp that I am working on:
http://www.marklevinsonlexus.com/overview.asp?model=gs
Old 20th September 2006, 05:42 PM   #85
FastEddy's Avatar
Default Cool for Lexus!
... and that looks like a complicated system.
Photonicube: does this (or any other) mobile audio system have any active, powered noise cancelation ... I'm getting older and appreciate less noise in my ride whether from inside or outside = my latest bugaboo is tire noise ... selecting tires with low noise tread, etc.
I recently bought that Bose headset that can plug into cell phone or audio system ... and appreciate their approach ... just wondering if something like that is happening in car audio??
Old 20th September 2006, 08:24 PM   #86
Default Re: Cool for Lexus!
Yes, it is we actually have it enabled on our Mark Levinson amps / head units. We have the ability to do noise cancelation on our most of our newer JBL and Infinity OEM amps/head units but it is not a cheap option for car manufacturers to buy, so they usually don't and when they do want it they normally buy the ML3-XX.
My DIY UcD amp from the junk box acid_k2 Class D 34 5th April 2012 08:03 AM
I found more junk! Magnetmaz Tubes / Valves 9 28th December 2007 08:49 AM
JYD (junk yard dog) cnctooltek Multi-Way 10 18th October 2006 03:50 PM
Tip for Junk box Zen PSU? SM7UYJ Pass Labs 2 4th April 2005 09:57 PM
Just got new junk from my friend Giaime Solid State 29 22nd March 2005 12:29 PM
Page generated in 0.09527 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
