| Class D Switching Power Amplifiers and Power D/A conversion |
#481 |
more picts
#482 | |
2N3906 or bc639 will these work in totem pole and gate drive they are non smd to-92 package ![]()
#483 | |
#484 |
thanks freda . will remove D7&D16 also Replace Q5&Q23 Q3,Q21,Q22,Q4 with BC639.
also i have made 2 pcb and both behave the same i have triple checked them for short and other issues. the idea of parallel the fets i borrowed it from here GZPA Class D 4000W with IRFP264 here is the pcb |
#485 | |
The layout is not an optimal one for class-D. You considered a power plane but it is not the only one issue to give attention. One knows that discrete UCD circuit generates lower EMI if the correct layout topology followed. Just remove two of the output mosfets from each rail and leave the two of which are close to the center of the board. The 47pf's in the input pair should be replaced with 1n to 4.7n. If i were you, i would not try to do this one before testing your capability with an already made circuit. There are several examples in the forum with toner transfer files and correct component values. I hope you have a scope to see and record what is happening in the cricuit when you applied power. Try to work with +/-12V before +/-60V. And please put bulk caps (+one or several 100nf) from positive and negative PS rail to GND. |
#486 |
thanks freda. this schema has been working . but with irf540 +/-38vlts or either irf640 even irfp250 +/-55vlts but single not paralled and has been o.k now it is when i tried to get more that's when all my problems started i would love to do the above projects but i'm limited to smd components. with single outputs this circuit was working o.k
#487 |
Hi
I'm fairly new at constructing anything on a breadboard but unfortunately my college decided to give me a project to build a fully discrete class d amplifier. I am considering building off the schematic posted in the first page (Phillips) just to know what exactly I'm up against. From there, try to construct my own class d amp with the given specific requirements. Do you guys have any good advice for me because I really feel like my school just threw me in a fire and told me to dance ): .. So far, for my own, I've made a triangle waveform generator using only discrete parts lol (http://dl.dropbox.com/u/14329675/trianglewaveform.PNG). So far I've studied that a class D has some parts which are the triangle waveform generator , the comparator to compare the waveform with the audio signal, the actual output stage and then a filter to change it back to an analog type waveform. Anyway I don't want to write my life story but any advice would be appreciated! Thanks! |
#488 |
With these typical 1970s class B layouts you won't get very far in class D. The current loops involved have to be considered for part placement and pcb track drawing. You can't do a good layout if you can't imagine how the schematic works.
I use to feel like the small child in The Emperor's New Clothes tale
#489 |
hi all where does one adjust the switching freq in this schema?
#490 |
Place a diffrentrial resistor in place of R9....it sets freq and dead time u need to set that for every mosfet if u change......i had posted a new thread after finishing with this thing....take a look at it..u can see I had cut a resistor below...i placed a potentiometer instead....but I can say its simple and awesome......with higher voltage....it is better than Ir2110
| a nice application note about damping LC networks "snubbers" | mirlo | Power Supplies | 7 | 11th November 2005 09:46 PM |
| 10w class d amp. application note | partyjups | Solid State | 1 | 8th March 2002 10:46 AM |
