Philips UCD application note
Old 16th February 2010, 11:11 AM   #471
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Originally Posted by selfservice View Post
Where did you get that info? I've googled a lot but nothing came up...
Are you sure the rights are philips property and not hypex property since they hired the inventor?
The quote comes from the Philips app note, dated March 2006, titled "LV MOSFET applications". Philips/NXP hold the rights to the patent, even though it is in Bruno's name. I checked this with NXP over two years ago, specifically because I needed to check the requirements for commercial use of the patent.
Old 17th February 2010, 08:52 PM   #472
Steven is offline Steven  Netherlands
Steven's Avatar
Thanks. I know I did not invent this license agreement myself, but I could not find it back. You're right, it was in that application note. I just didn't save a copy.
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 18th February 2010, 06:58 AM   #473
Ouroboros's Avatar
That app-note seems to have disappeared from the NXP web site now. I still have an electronic copy if anyone wants to see exactly what it said.
Old 3rd November 2011, 07:31 PM   #474
elektryk is offline elektryk
elektryk's Avatar
Hello, I'm new on this forum.
I projected PCB for an amplifier, and skipped Q3 and Q4.
Will this layout and PCB work?
Sorry, I'm amateur of PCB projecting and some routes are wired.
Btw. I'm not good at English.
Old 26th February 2012, 04:30 PM   #475
stewin is offline stewin  Kenya
yes it will work but pls post the value of all the componennts.
Old 28th February 2012, 04:37 PM   #476
elektryk's Avatar
Values of components are the same as on the orginal schematic (except transistors) but his names are diffrent.
Is it a good idea to use 2N5401 for driving mos-fet? (driver -Q6, Q9 on my schematic)
I cant buy orginal parts and I'd use other parts, or make amp on IRS2092, but i don't know which will be better and cheaper.
Old 28th February 2012, 06:01 PM   #477
ChocoHolic is offline ChocoHolic  Germany
For Q6 and Q9 better choices would be BC369 or BC807.
2N5401 is fine for Q8 and Q10.
Old 2nd April 2012, 05:50 PM   #478
why are these bc369 better
Old 2nd April 2012, 08:11 PM   #479
Whortless is offline Whortless  Turkey
Whortless's Avatar
Or a better low VCEsat (biss) transistor such as PBSS5140T or 5240T or similar transistors would be an option.
PBSS5240T pdf, PBSS5240T description, PBSS5240T datasheets, PBSS5240T view ::: ALLDATASHEET :::
Old 2nd April 2012, 10:14 PM   #480
hi whortless i have made the below schema but q13,14,3 & 21 plus the aux +12v section fails vltg is ir2110 smps +/- 55vlts but my outputs fets are o.k . what is my error?
diysmps
Philips UCD application noteHide this!Advertise here!
a nice application note about damping LC networks "snubbers" mirlo Power Supplies 7 11th November 2005 09:46 PM
10w class d amp. application note partyjups Solid State 1 8th March 2002 10:46 AM
