Philips UCD application note - Page 47 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 5th August 2007, 10:39 AM   #461
tawn10 is offline tawn10  United Kingdom
Originally posted by TOINO
Sorry…I can’t help everybody.
Now you know the equipment references. That is the difficult part.
Last night I have found another one with UCD, but have not the schematic.
They call the amplifier module CUD-S400 . It is what is marked on pcb.
The output transistors are 2SK3607-01MR
Turn off transistors 2SA1954
Drv BC857CW
Gate diodes BAS316.
Cascodes between comparator and driver 2SC2713
Input BC856BW
Suply regulated SMPS +44V -44V
YAMAHA portable Pa system “STAGEPAS 500”
I find it interesting that a system consumes 65w of power and outputs 500w of power?? how does that work!
Old 5th August 2007, 01:25 PM   #462
Philips FWM730 service manual. Size 34mB
http://rapidshare.com/files/47100154...ice_manual.rar
Old 5th August 2007, 02:13 PM   #463
TOINO is online now TOINO  Portugal
TOINO's Avatar
Strange times my friend…
The market has so many of these miracles as the hell of good wills.
Yo no creo en brujas pero que las hay... las hay (Cervantes)
Old 5th August 2007, 02:55 PM   #464
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I think that the built-in amplifier is actually 2x200Wrms@4 ohms and 2x120Wrms@8 ohms, assuming that the SMPS can handle those power levels continuously (but it probably can't as continuous operation at full power is not required at all with music).
On the other hand, they don't specify the nominal impedance of the loudspeakers, but it may easily be 8 ohms so that an optional second pair can be added... Could you enlighten us about that, Toino?
Anyway, it must be noted that a 2x200W SMPS class D system can easily play music at clipping threshold while drawing only 65W or less. In comparison, a traditional class AB system with stone age power supply would be probably drawing 265W and wasting 200W as heat...
I use to feel like the small child in The Emperor's New Clothes tale
Old 7th August 2007, 05:24 PM   #465
Hi!
your Philips FWM730 service manual show this protection circuit:
Old 7th August 2007, 05:30 PM   #466
Question ... UcD output stage and current sense
protection circuit is for 2 UcDs. My question is if the last circuit act as a latch in case of overcurrent detection
UcD output stage with current detectors:
Old 7th August 2007, 08:00 PM   #467
or is it a relaxation oscilator? (upper part around 7210-C 74HC14D)
Old 15th February 2010, 08:30 PM   #468
Originally Posted by Steven View Post
Philips released its UCD application note.
The UcD concept was patented by Philips. However, the use of the IP is granted (without a license fee) to third parties that use the enabling semiconductor components from Philips Semiconductors in their application.
Where did you get that info? I've googled a lot but nothing came up...
Are you sure the rights are philips property and not hypex property since they hired the inventor?
Old 16th February 2010, 10:20 AM   #469
AP2 is offline AP2  Italy
Banned
Originally Posted by lumanauw View Post
In this DIY UCD, in the input differential, there are capacitors C42-C44 valued 22pf connected to ground.
What is the function of these capacitors?
the function of these two capacitors is to suppress the Glish due to the junction of the diode (behavior with high frequency signals).
Old 16th February 2010, 11:04 AM   #470
Banned
C40-C45 (22pF) also have the same function.
This interpretation has been looking at the schematic on this thread.
a nice application note about damping LC networks "snubbers" mirlo Power Supplies 7 11th November 2005 10:46 PM
10w class d amp. application note partyjups Solid State 1 8th March 2002 11:46 AM
Copyright ©1999-2017 diyAudio
