Philips UCD application note
Old 4th March 2007, 06:32 PM   #371
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
From above:
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 4th March 2007, 06:34 PM   #372
Baldin's Avatar
Close up:
Old 4th March 2007, 06:40 PM   #373
Baldin's Avatar
From the back .....
Why are Specon connectors only used for prof use???
They are such good conectors, takes up to 4 mm^2, can be pluges in while the amp is turned on. They are quite inexpensive compared to all things golden. Can only be recommended
Old 4th March 2007, 06:45 PM   #374
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Originally posted by Baldin
But there was a problem with a high pitched tone being present all the time.
Think I've heard this before, when trying to put two amps in one case. As I recall it should help moungint the two amps as close together as possible .... but that was what I thought I hade already done.
Would it help syncronising the amps??
And hould bould that be done as easy as possible??
IT also have some 100 Hz "noise" .... gues it comes directly from the PSU.
Hi Baldin. Does the high pitched noise go away if you only have one module powered? If so, the two modules are definitely interacting. It may help to physically space them farther apart.
Reloacte the rectifier side of the power supply board as far away from the module wiring as possible. That should help reduce the 100Hz noise a bit. Also try twisting the power supply wiring together for each module if possible.
Brian
Old 5th March 2007, 04:13 PM   #375
lumanauw is offline lumanauw  Indonesia
lumanauw's Avatar
Send a message via Yahoo to lumanauw
I found a RM core, but the material is N27.
From a quick search on the net, this material is made by Siemens, and intended for power transformer below 100khz.
Is this RM core (N27) can be used for UCD output filter (with fosc near 500khz)?
Old 27th March 2007, 12:21 PM   #376
lumanauw's Avatar
Has anybody experience this? When the mosfet's heatsink is attached to the case (=grounded), the residual output get distorted (sinusoidal becomes wrecked)?
How to counter this? The heatsink needs to be grounded, how to advoid this? I think this is because the low side Drain actually=full swing, and when this transistor gets grounded, it forms a capacitor between transistor's base metal plate (=full swing) and heatsink (=ground).
Is this why the real UCD uses plastic mosfets?
Old 27th March 2007, 12:33 PM   #377
stepheno is offline stepheno  South Africa
You should isolate the Fets from the heatsink by using appropriate TO220 insulating heat transfer material. Otherwise you would have a short from the supply rails to ground every time a fet switches ON.
Old 27th March 2007, 12:46 PM   #378
My apology: Mounting the top fet directly to the heatsink (ground in your case) will short the positive rail to ground. Also, when the bottom fet switches on, you will be shorting the negative rail to ground. Use thermal insulating material.
Old 27th March 2007, 12:52 PM   #379
lumanauw's Avatar
Hi, Stephano,
I've used insulation mica and goop. The effect is very obvious. Do you also see this in your UCD?
Old 28th March 2007, 04:27 AM   #380
lumanauw's Avatar
The insulation material used in UCD400 and UCD700 looks thick, white coloured. Maybe it will reduce the capacitance effect between transistor flange and heatsink/ground.
What insulation material is it?
Philips UCD application noteHide this!Advertise here!
a nice application note about damping LC networks "snubbers" mirlo Power Supplies 7 11th November 2005 09:46 PM
10w class d amp. application note partyjups Solid State 1 8th March 2002 10:46 AM
