Charlize Drop-Out Problem
Old 25th August 2006, 11:42 PM   #1
serengetiplains is offline serengetiplains  Canada
serengetiplains's Avatar
Default Charlize Drop-Out Problem
I have two Charlize Tripath amps serving duty in a bi-amp system. Sometimes just after turning both amps on, or upon pushing them hard, one of the amps will turn on and off on a 2 second cycle. I don't think this is entirely temperature related problem given it happens when the amps are cold on turn-on. It's not a big concern, because I've always been able to solve the problem by turning the amps off and on again. Anyone know what might be happening?
Old 26th August 2006, 12:40 AM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Sonds like you're tripping some part of the protection circuitry. Could be over current since you said you were driving them hard.
Brian
Old 26th August 2006, 07:16 AM   #3
Pano is online now Pano  United States
Pano's Avatar
I had a couple of Fenice20 boards that did that. Just had to turn them down.
When the amps start to cut out like that. you're clipping badly anyway. But some of the chips seem to be more sensitive than others..
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 26th August 2006, 09:34 AM   #4
classd4sure is offline classd4sure  Canada
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Could this be ripple related... as in bad electrolytics? Variation within the IC itself shouldn't be too much? What components are associated with this protection circuitry?
Old 27th August 2006, 08:20 AM   #5
vt4c is offline vt4c
From your description, I would strongly believe that Charlize has been over-driven. There was a similar case reported by a fellow member here sometime back.
Charlize Drop-Out ProblemHide this!Advertise here!
Problem with Charlize amp Nikola Krivorov Class D 1 6th February 2009 03:44 PM
First DIY project, Charlize problem atldiyr Class D 3 15th September 2008 07:42 PM
Problem with my charlize Radian Class D 0 3rd June 2006 08:12 AM
charlize problem jonastus Class D 4 13th May 2006 01:44 PM
Charlize input cap problem - Help! KT Class D 9 10th February 2006 03:22 PM
Copyright ©1999-2017 diyAudio
