| Class D Switching Power Amplifiers and Power D/A conversion |
Anyone have any experiance?
Still think it needs a bit warmth. Is there any cheap projects out there that could work and sound good? |
#2 |
#3 |
Thanks for the serious answer in this topic...
#4 |
I agree that the T-amp need a liitle warmth. I have my modfied SI T-amp connected to a Bottlehead Foreplay tube preamp. The tube preamp provides just the proper balance for this T-amp.
My 41HZ Amp6 does not really need the preamp. The Amp6 sounds warm enough without a preamp. It is a matter of taste.
Davet |
#5 |
Solve. Do a search under "puffin" and you will find some infomation about this that I posted some time ago.
#6 |
Puffin.I did a search and found some parts about tubes but not to specific?
Any recomendations out there? Build your own? |
#7 |
This one looks cool!
http://www.autocostruire.it/modules....rticle&sid=103 |
#8 |
diyAudio Moderator Emeritus
Change the input coupling caps (good mod) and slap on some aircore inductors and you'll probably get the warmth (a.k.a. distortion) you're after.
Brian |
#9 |
BWRX, in your opinion, t-amp does not require any kind of tube preamp?
what about the need for extra inputs? Somehow I don't find this option very attractive: http://www.tnt-audio.com/ampli/t-preamp_e.html |
#10 |
I don't think it needs a tube based preamp, but they can certainly sound different with a preamp. Whether or not it sounds better is up to you to decide. I've used a very simple buffered volume control setup with a couple of TL072s from TI and think it sounds nice. I also tried NE5532 from Philips but it had a slightly different character that wasn't as pleasing to me.
I don't use my Tripath based amp anymore because the little D10.1 modules based on the MP7720 sound better I'd imagine part of that is due to the DC coupling (no input coupling caps). In the near future I'm looking to build an active crossover (with volume control) to drive the little modules, or any other amp for that matter.
Brian |
| FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner | joe-electro | Swap Meet | 0 | 31st May 2009 04:14 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| tube preamp using submini tube | unclejed613 | Tubes / Valves | 11 | 19th August 2007 07:14 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 05:28 PM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| Page generated in 0.10263 seconds (77.84% PHP - 22.16% MySQL) with 10 queries |
