Help on calculating first order SD filters - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 23rd August 2006, 01:32 PM   #11
Yes. Im sure of it. And takin a look in the FFT of the out of a SDM we can see the effect of the integrator in the modulator, including in the audio band there is a high pass filter for noise.. But in simulation, with a low pass filter setled to 10KHz the effect remains the same, the only difference is that the noise, now does not decline with low audio frequencies but remains the same for all audio band. The SNR is the same for all audio band, understand ?
Master graduating
Old 23rd August 2006, 02:00 PM   #12
While I welcome this kind of spectral distripution regarding THD of amplifiers for instance I would definitely go for the decreased SNR at low frequencies since someone with a hearing impairment would probably profit from it.
Charles
3 way speaker with 1 order filters Hyldal Multi-Way 191 29th January 2008 06:29 AM
1st order filters/crossovers with proper drivers compared to full range? tech.knockout Multi-Way 8 15th May 2006 06:52 AM
Problems with calculating an 8th order (SubSim) zoofelix Subwoofers 3 27th January 2006 11:29 PM
second order lc filters Ilianh Multi-Way 29 25th November 2002 05:24 PM
Copyright 1999-2017 diyAudio
