Go Back   Home > Forums > Amplifiers > Class D
Old 6th November 2006, 01:41 AM   #11
Fin is offline Fin
Fin's Avatar
How good would these be for the SI T-Amp?
Swithchmode PS on eBay Australia
If anyone is interested, I could buy then and forward them on to you.
Fin
Old 6th November 2006, 02:45 AM   #12
will a better power supply give me more bass? I am using a 1A one
Old 6th November 2006, 02:50 AM   #13
Fin is offline Fin
Fin's Avatar
From what I've read you really need more than 1.5 Amps and above 2A is even better. Apparently it does help the bass and so does a large stiffener cap - but the real cure for the lack of bass is to replace the two input caps with larger ones (up to 2.2uF).
Fin
Old 6th November 2006, 02:50 AM   #14
sx881663's Avatar
Default Appropriate power?
Fin,
This supply is rated up to 40 watts which means it can put out just short of 3 amps continuous. This is enough to run 2 SI's easily. It is physically quite a bit bigger than the 2" X 4" supplies I use. If it will fit in the case you plan on using I see no problem in giving it a try. I would recommend a bulk storage cap of 10,000 to 20,000uf near the amp circuit. Run the supply leads to this cap first then on from it to the amp. Twist the leads!
If the supply makes an audible chirping kind of noise this should be correctable by putting a load resistor right on its output pins. Use a 10 watt res of around 36 ohms. Running it at 5 watts should insure long life. It should be better without this res, if you don’t need it, don’t use it. This is due to the increased ripple current generating additional noise.
Roger
Wow, you guys are too fast for me!
A 15 watt supply will cover all the power the amp can put out long term. Most of these supplies will put out 20 watts or so short term so more is not needed. A smaller supply run at what it was designed to provide will perform better than a larger supply utilized to only a fraction of its capabilities. It will have lower noise and probably better regulation as well. Lots of variables here so can’t state this as absolute fact in all cases.
Happiness is being owned by a cat
Old 6th November 2006, 02:56 AM   #15
Fin is offline Fin
Fin's Avatar
Hi sx881663
Thanks for that. I might buy a few and this low price. They could be usefull for future projects too.
Fin
Old 6th November 2006, 07:01 PM   #16
Pano is offline Pano  United States
Pano's Avatar
Shootz! At that price, buy several. Hard to go wrong.
Just be careful boxing it up. Mains voltage and all.
Take the Speaker Voltage Test!
Old 7th November 2006, 12:20 AM   #17
Fin is offline Fin
Fin's Avatar
Thanks Michael
I will get some.
Fin
Old 7th November 2006, 11:43 PM   #18
Fin is offline Fin
Fin's Avatar
OK - well I just ordered four of these power supplies. The seller says he will be happy to do a special price if anyone is interested in a bulk buy. I didn't think that the price could get any better than $5.20AUD = $3.50US!!!
Fin
Sonic Impact power-amp - biamping vs. bridge? htgeek Class D 1 19th May 2006 05:14 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
How can I make a power amp from Sonic Impact? hsu Class D 7 11th January 2006 03:32 PM
Sonic impact, which power lead is +ve? gilbodavid Class D 2 3rd November 2005 05:22 PM
Using this device to power Sonic Impact justpoor Class D 4 8th March 2005 02:52 AM
Page generated in 0.08066 seconds (84.84% PHP - 15.16% MySQL) with 10 queries
