| Class D Switching Power Amplifiers and Power D/A conversion |
hello guys
i'm going to build the biggest amplifier ever built by me ![]() the main trouble is the power supply, a toroid is too much expensive and too much weight. so i have decided for a switched mode power supply ![]() i've found a design for a 700W power supply and i've modified it to deliver a maximum of 1000W, 80+80V. here is the layout and the top and bottom layer, i'm searching for suggestions and improvments before producing the pcb. of course is possible to order more pcb if you want one of them
#2 |
#3 |
some trouble with the links...
try to copy and paste this: www.cronokart.com/images/images/sch2.JPG www.cronokart.com/images/images/sch3.JPG www.cronokart.com/images/images/bot.JPG www.cronokart.com/images/images/top.JPG www.cronokart.com/images/images/layout.JPG |
#4 |
Hi Selfservice,
There are some errors in the attached schemas. C72, C73, C76, C77 are misprinted, they need to be diodes. A graetz bridge, for that power a 600V/25A type is needed. In the +/-12V supply a 7912 is needed in the lower side. On the margin it looks an interesting project. Regards, |
#5 |
thank you for the quick reply!
for the graetz bridge there are faston connectors for the bridge to be applied on the heatsink via some cables, for simplyfing the layout. for the -12V, cause is used only by the op-amps, i've decided to use only a resistor and a zener diode. the +12V is used also for the SG IC and so i've decided to stabilize it. |
#6 |
Seems to be a very good idea for anybody who dares in life....
Do you know the mains transformer ratio/turns? And what about the current transformer? |
#7 |
the turns for the current transformer have to be found experimentally, i haven't tested the trasformer at full power, so i don't know the exact turn ratio.
for the main trasformer are 28 turns for the primary and 12+12 for the secondary |
#8 |
Great looking project! If this turns out to be working well I'd definately be interested in building one!/Anders |
#9 |
I'd also be intereste in a pcb if you get this thing to work.
#10 |
Very thanks.very good designe.What is T1 transformer.ETD49,ETD54 etc..?
| Class AB Power Supply Design | pjpoes | Power Supplies | 0 | 15th May 2007 10:45 PM |
| 1000W Power Supply Design | selfservice | Power Supplies | 3 | 18th August 2006 05:53 PM |
| Power Supply Design for a solid state amplifier | elaar | Power Supplies | 61 | 9th July 2006 08:18 PM |
| Looking for a CLASS D amplifier design . | darkm4n | Class D | 4 | 19th October 2005 11:49 PM |
| Class-G amplifier with PWM supply ! | B.I.G | Chip Amps | 2 | 19th March 2005 07:32 AM |
| Page generated in 0.10814 seconds (79.14% PHP - 20.86% MySQL) with 11 queries |
