Tripath a phase fake?
Old 6th August 2006, 04:56 AM   #21
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Originally posted by KBK
The tripath amps have a free running 300khz (at least in the 2024 chip info that I have poured over) osc. I'm not quite sure of it's function yet, even though I've read some of the technical papers. Could some one point to the full educational info on such, or clear that up for me?
That free running 300khz info is in regards to the on board charge pump. The charge pump provides a voltage greater than the supply voltage from which the gates of the high side mosfets are driven. The frequency the charge pump operates at has nothing to do with the switching frequency of the amp.
Brian
Old 6th August 2006, 06:42 PM   #22
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Tripath can be decent, but falls short compared to better designs. Why keep kicking the same ol horse?
I can think of one reason...... price.
Take my setup for example. I have three AMP1-B's, thats 6 channels of amplification that cost less than $200. A 6 channel setup using ColdAmp, Hypex, ZAPulse, or anything else thats considered superior to TriPath would break my bank.
If money isn't an issue, I would agree that there are far better choices than TriPath.
Old 8th August 2006, 08:07 PM   #23
Solve is offline Solve  Sweden
Solve's Avatar
[i]Originally posted by panomaniac
Why don't you test it? That way you will know for sure.[/B]
I dont have the equipment or the knowledge to do it.
Originally posted by soongsc
I would also be interesting to find how the phase differences compare with phase differences in speakers.
Yes!Maybe its only out to the speakers?
Im no expert...
I dont have so much experiance of good sounding hifi so T-amp
was a realy nice kick for me!
So, realy i dont know what to compare with?
You tell me?
But.
Still we talking stereo?
Ok.
I dont know...but for me its an very wide stereo in Tripath.
I never heard so wide stereo!
Maybe thats why i like it.
But my complains is thats it maybe to wide.
You know those cheap stereos with presets of wide stereo effects?
So, just asking if somebody with equipment could measure if its
something fishy between Left and Right in phase.
Solve
Old 8th August 2006, 11:22 PM   #24
The golden mean is offline The golden mean  Sweden
The very best conventional amps(non Class D) may have as little as one or two degree(s ) phase shift in the audio band.
A coil (inductor) in the output pathway of a conventional amp may cause a phaseshift(delay), in the feedback loop , if the amp is a NFB one.
Which may very well effect the sound.
Some manufacturer claimed that phaseshifts in amps, first of all effected our perception of the bass. I donīt know at all, if this is true, but some may investigate.
On the contrary , many swear the bass to be the forte of class D amps....
An input filter, with a low and steep corner frequency, may also effect an amps phase response.
Without wonderment,no life.
Old 9th August 2006, 12:11 AM   #25
soongsc is offline soongsc  Taiwan
soongsc's Avatar
From the traditional amps that I have measured, phase shift seems to be very small compared with speakers. I have not measured a class D amp yet (my AMP2 is still not working), but I'm quite sure it can't be worse that speakers.
Hear the real thing!
Old 9th August 2006, 03:48 AM   #26
Pano is offline Pano  United States
Pano's Avatar
I had a qucik look at a Fenice20 amp today. This uses the same chip as the Sonic Impact Amps.
I see NO phase difference between channels over most of the audio spectrum.
There was a little phase trouble in the top octaves, but not much.
The amp is a little tricky to measue in XY mode, as the speaker actually does not see ground. I tested between positive and negative output posts on both channels and found the 2 poles to be 180 degrees out of phase, as one would expect. Then phase was measured between L+/R+ and they were in phase. Same for L-/R- in phase. I assume that means all is well.
I did, of course, first measure phase between left and right at the amp inputs. No problems. Sine waves and worble tones were used.
As I said, there was a slight phase problem up high, I will look into it further. Will also measure phase after the input caps.
But at first look, the phase seems to track very well between Left and Right.
Take the Speaker Voltage Test!
Old 11th August 2006, 08:33 PM   #27
Solve's Avatar
Thanks panomaniac for the test.
Hope this clear my thoughts that it was an phase problem out there.
"180 degrees out of phase"
What does that mean?
Is that common?
Solve
Old 11th August 2006, 08:43 PM   #28
BWRX's Avatar
The outputs are bridged so one speaker output will swing toward the positive rail while the other output will swing toward the negative rail. Or you can say the waveform on the - output is 180 degrees out of phase with the waveform on the + output.
Brian
Old 12th August 2006, 12:26 AM   #29
Solve's Avatar
Does it it say "it sounds out or phase"
or..?
Just wonder...
I give my friend who works with sound a try.
It sounds good!
But not right...
Solve
Old 12th August 2006, 01:30 AM   #30
soongsc's Avatar
Has anyone tried to measure the spectral decay of amps with speaker loads?
Tripath a phase fake?Hide this!Advertise here!
Are these fake? glen65 Solid State 30 7th July 2007 04:45 PM
KEF driver phase and the H-B generated phase dlr Multi-Way 11 24th April 2007 11:56 AM
Fake Law Log Pot DolbyR Parts 7 17th January 2006 10:55 PM
Law fake pot Nordic Chip Amps 10 25th November 2005 11:33 AM
dipole sub H-Frame, phase or opposite phase ? mbon Multi-Way 6 19th June 2004 08:36 PM
