Go Back   Home > Forums > Amplifiers > Class D
Old 30th July 2006, 10:03 AM   #1
fokker is offline fokker  China
Default DC step down converters vs. Class D amps
doesn't it seem to you that the two are quite similar? they all have a pwm comparator, driven some sort of switches. a half-bridge based step down converter looks almost identical to a typical post-filter Class D amp.
The difference, of course, is that a DC converter may not be fast enough to respond to an audio signal but isn't it worth tryint to find out?
Here is a TI chip, TPS50052, a step-down converter good to 40v. it has a pwm comparator, and build-in gate drivers.
all you need to do is to redesign the filter, and inject the input signal to the Vfb node, with a resistor to control gain.
alternatively, you can use one of those pwm controller chips to generate a pwm signal and use that to drive switches.
Has anyone tried it yet? would it work in real life?
Old 31st July 2006, 01:27 AM   #2
mirlo is offline mirlo  United States
It might be workable, but I believe that most of the better class-D designs are either based on sigma-delta data converter architectures or are self-oscillating, not fixed frequency PWM based.
Old 31st July 2006, 02:28 PM   #3
the one thing i can see from the datasheet of the ti chip is long propogation delay - not an issue with dc converters but an issue for audio.
I do not know how important it is to be self-oscillating or have fixed frequency.
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Step up voltage on class d ASLHK Class D 4 7th September 2008 01:02 AM
my first step to class A amp -aleph3 3ow. space2000 Pass Labs 11 20th June 2008 08:24 AM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Page generated in 0.55279 seconds (14.92% PHP - 85.08% MySQL) with 11 queries
