Class D driver Class D driver - diyAudio
Class D driver
Class D driver
Old 24th July 2006, 08:20 PM   #1
epilot is offline epilot  United States
Default Class D driver
I need a class D amplifier that works at 60kHz as a piezo driver
I was not able to find a popular chip in my location so it should be made of transistors.
Old 24th July 2006, 11:38 PM   #2
SpittinLLama is offline SpittinLLama  United States
Why do u want to use a Class D amp to drive a piezo?
-SL
Old 25th July 2006, 02:22 AM   #3
-SL
Just for a project
Old 25th July 2006, 05:09 PM   #4
Well a piezo speaker looks more like a capacitor than a inductor and resistor like a dynammic speaker using a voice coil. Not sure how Class D would hanlde this load plus a piezo is more efficient than a dynamic so fi you want Class D for efficiency you may not need it really. Maybe someone who has tried to do what you are can give some input.
-SL
Old 26th July 2006, 05:38 PM   #5
3-LockBox is offline 3-LockBox  United States
Curious to know what kind of project it is.
Is building the amp yourself a requirement of the project or are you just trying to save some money. Otherwise, any old amp will do if all your doing is driving a piezo. But you need to add a resistor at least, or you could burn up an amp, Class D or otherwise.
(insert clever anecdote here)
Old 27th July 2006, 05:39 AM   #6
phase_accurate is offline phase_accurate
Do you just want to reproduce 60 kHz constantly and nothing else ?
In this case there are simpler solutions than a class d amp.
How about a switching stage (50% duty cycle) followed by a tank circuit ? The latter could even be used to transform the audio to a higher voltage if needed.
Charles
Old 27th July 2006, 06:55 AM   #7
kartino is offline kartino  Indonesia
kartino's Avatar
Some kind of mosquito or rat repellent? Why don't use simple signal generator?
Or it is just project?
Old 31st August 2006, 07:49 PM   #8
Howard Tam is offline Howard Tam  Hong Kong
Default Piezo driver
Hi !
You could look into Apex Micortechnology, they had good class D
piezo driver.
http://eportal.apexmicrotech.com/mainsite/
Class D driverHide this!Advertise here!
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
which class D amp to run bass driver 56oval Class D 16 4th September 2007 08:57 AM
Class A2 SET using source follower driver Audio_idiot Tubes / Valves 10 2nd December 2006 12:21 AM
Wanted TA0104A Tripath Class T driver IC screamer Swap Meet 0 13th January 2006 10:07 AM
Driver stages for my SE Class A amp RichardJones Solid State 7 9th October 2002 06:10 PM
Copyright ©1999-2017 diyAudio
