Modified ColdAMP SPS80
Old 12th October 2006, 01:01 PM   #41
ackcheng is offline ackcheng  Hong Kong
Send a message via ICQ to ackcheng
Thanks. I think I will take your advice and remove one cap on board. I will change the other one to BHC ALC40 1000uF, 100V. It has a diameter of 25mm and teh space between the legs are 10mm. In other words, a drop-in replacement! Then i will pull out the wire and connect it to an external cap as you have uggested.
Have you noticed any deterioration in speed by adding 10,000 uF caps?
Old 12th October 2006, 01:50 PM   #42
ghemink is offline ghemink  Netherlands
Not really, but that would be difficult, I`m using the SPS80 now only for my woofer amps. However, I think the ELNA`s are probably pretty fast caps (others any opinion?), they also have very low series resistance, I could not find any datasheets on the big ELNA Cerafines, however, when I tried to measure it I found something like 3mOhm, this is very low. As a result, the cerafines do a very good job in supressing any remaining noise from the SMPS. In fact, when connecting the external caps via twisted wires, you add a kind of LC filter (L of the wires and the C of the caps) this gives additional HF filtering.
Gertjan
Old 16th January 2011, 08:09 PM   #43
v-bro is offline v-bro  Netherlands
v-bro's Avatar
This is what I did:
They are 1200uF Panasonic FC caps, if you want low ESR then just parallel a bunch of smaller caps... And yes, I kept a few on board as well to prevent EMI issues.
My goal was rather to be able to fit it in the 1U high box, because the original caps were simply too high profile. I didn't really mod the caps to improve the performance....
We'll see (hear) what this baby can do when it's finished!
http://www.41hz.com/forums/showthrea...fier-with-AMP2
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 17th January 2011, 04:49 AM   #44
luka is offline luka  Slovenia
luka's Avatar
mmm amp2!!
have you solder the 2350 to the board of termal paste? enough cooling or does it get warm?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 17th January 2011, 06:12 AM   #45
v-bro's Avatar
Just solder it well, I've got some tricks up my sleeve for that... I've built many of them and measured with my IR thermometer, doesn't run over 45-50 degrees celsuis.
If it runs hotter then either the fets or the gate drive resistors are not well matched/wrong type...
Old 17th January 2011, 06:27 AM   #46
luka's Avatar
50 is too much for me, since it will go into car, where can be 40 or more (depends where amp will end up) to start with... I added heatsink on top side, which help A LOT.
Can you reveal how you solder it, coz when I did it, it went just as it was said it would.
I FEEL SLOVENIA
Old 17th January 2011, 08:10 AM   #47
v-bro's Avatar
I think it's the chip who decides if it is too much, not you personally...
This temperature is hardly above ambient, so I don't know what the big deal is. Standard AB car amps run at above 60...
Old 17th January 2011, 08:16 AM   #48
luka's Avatar
very true, still I like if it is cold to the touch, probably has even longer life because of that
I FEEL SLOVENIA
Old 17th January 2011, 08:40 AM   #49
v-bro's Avatar
Nonsense, this chip is extremely heat proof and with IR I am measuring core temperature. This is nothing you will burn your fingers on....
Old 17th January 2011, 09:15 AM   #50
luka's Avatar
How come you see it as nonsense, while you know, that if IC heats up, PCB heats up and transfets heat to capacitors, that have temperature dependent lilfe time and they will fail faster, if capacitors fail, IC could fail... you are looking over too short of the time period and environment that is not home!
I FEEL SLOVENIA
Modified ColdAMP SPS80Hide this!Advertise here!
testing of SPS80 SMPS ackcheng Class D 32 23rd August 2011 07:31 AM
FS: COLDAMP one SPS80 power supply & two BP4078 modules in MK12 Case BongFish Swap Meet 2 18th March 2009 03:17 PM
UCD700 and SPS80 HV - noise problem Fabian Class D 7 25th November 2007 08:43 AM
UCD 400 and Coldamp SPS80 SMPS ptwining Class D 1 22nd September 2007 04:43 AM
Potentially WTB Coldamp SPS30/SPS80 DonoMan Swap Meet 0 2nd June 2007 06:04 PM
