| Class D Switching Power Amplifiers and Power D/A conversion |
#11 | |
Account Disabled
Easy enough. Add another wire. V+/GND (two twisted wires) and Gnd/-V (two more twisted wires). The output ground formed by the cap common just goes straight to the amp power ground. I'd put the caps in front of the SMPS in order to them as close as possible, and all wires as short as possible. |
#12 |
Hi! ClassD4sure,
Would you mind to send me the photo of your connection?? I've try to connect the Caps like your suggestion, +Vin GND use a twisted wire connected to C7, and -Vin GND connected to C6, also the OUT+ & OUT - of the Four caps becomes the GND of the output. But the red LED on after I turned on the main power Thanks! |
#13 |
Account Disabled
A picture would be of little help, if you respected the polarities show in the diagram I gave you it should be OK. Give it a close double check that you didn't reverse one of the rails? |
#14 |
Some elco's top side also used as pressure release when explosion occur by overheating. Placing elcos also shall consider to where the direction of explosion.
#15 | |
I already check all the polarities, and nothing wrong. But also fail to power on! I don't know why? Could you mind to sen me a pic of the connections of your caps?? Thanks a lot for a kindly help!! |
#16 |
Thanks everyone help!!
My problems already solved, thanks a lot! |
#17 |
is it better with this new wiring?
#18 | |
So what was it then? |
#19 |
Actually, now I connected the Jensen Caps like classd4sure suggestion. For the best performance, we should connect in this way!
And also, I found that the sound becomes more muscial and detail, a possible way to modifiy your SPS80 in a best result. Now I am using 1.5mm Jensen solid core silver wire for the power paths and 1.0mm for the signal paths. Worderful result that I can found, transperant and powerful! More, I also setup two set of linear power supply for the input buffer of the UcD400AD
#20 |
Account Disabled
Good stuff!
Please inform us where you made your error, others who may want to follow might like to know. It's good that you don't require a picture now because for one thing I dont' have a camera and for another, I'm in the middle of re-wiring my own supply.. Glad the changes paid off for you. |
| testing of SPS80 SMPS | ackcheng | Class D | 32 | 23rd August 2011 07:31 AM |
| FS: COLDAMP one SPS80 power supply & two BP4078 modules in MK12 Case | BongFish | Swap Meet | 2 | 18th March 2009 03:17 PM |
| UCD700 and SPS80 HV - noise problem | Fabian | Class D | 7 | 25th November 2007 08:43 AM |
| UCD 400 and Coldamp SPS80 SMPS | ptwining | Class D | 1 | 22nd September 2007 04:43 AM |
| Potentially WTB Coldamp SPS30/SPS80 | DonoMan | Swap Meet | 0 | 2nd June 2007 06:04 PM |
