| Class D Switching Power Amplifiers and Power D/A conversion |
Hello,
I want to use IR2110 mosfet driver for a high power Class D bridge amplifier design i am starting. Could someone help me in biasing the IR2110 driver for single supply operation (bus Voltage is 50 volts) using IRF530 and IRF9530 pair?? An out of phase PWM signal is coming from a Schmitt trigger buffer 74HCT14 with a 5ns dead time delay between high side and low side from a 32 bit microcontroller. Thats all I have as information i have, as of now. If someone can refer a link or thread for read and get to know other than IR's AN748 and IR798 (a & b) it will be wonderful because these two notes got me confused... i will be really greatful... thanks and regards |
#2 |
The IR2110 is designed to drive a pair of N-channel FETs, so instead of your 530/9530 combination, you'll be able to use a pair of IRF530s.
There's a number of application notes on the International Rectifier site that show how the bootstrap power is arranged. If you're only using a low voltage rail, you might be better off using the National Semiconductor LM5104 (or another part in the LM510x range) instead. |
#3 | |
thanks Ouroboros... Since the design uses a intelligent device, I might be as well give a try to go beyond 100 volts bus voltage. I suppose IR2110 will be the right choice for this design. Moreover, since i will be commercializing this design i have to rely on the locally available components. IR2110 is less than 50 cents here (best in class i would say)... I have gone through many application notes from IR on using 2110... confusion is about using 4 of N channel mosfets in H bridge for single supply operation. I just can figure out how the whole thing will work on balanced current architecture... could you possibly guide me?? thanks again for all the help |
#4 |
Ouroboros !!
Razor_Edge is using the p,n channel mosfets as buffer to output mosfets ...U need to use a buck convertor first to convert 50v to 15volts.. IR2110 is normally used on 15volts rail...for Mosfets -ve supply is not required..but for IGBT's is a must for better turn off!! Bootstrap power (for driving high side mosfets)is obtained by using a fast recovery diode+capacitor combination. Pls do serch forum for more details..
SivanandBalan |
#5 |
Aah sorry! I should have read the original a bit more closely and realised it was for a high power design.
If the design requires an external power buffer between the IR2110 outputs and the power FETs then there's obviously no problem in powering the buffer to drive the lower FET, but the floating 12/15V supply driving the upper FET will need to be able to source more current than would be required if you were driving the output gate direct from the IR2110. Perhaps a seperate floating 15V supply from a dedicated mains tranformer might be the easiest solution? If you do use a seperate 15V supply fed from its own mains transformer, you should add a common-mode choke between the output of the supply and the power-amp. The top FET gate drive is swinging between the power rails at the switching frequency of the class-D amp and the C-M choke will prevent this large common-mode swing from causing a lot of ac current flowing to earth via the capacitance to ground of the floating supply. |
#6 | |
well, I am using an syncronous smps generating 12 volts for the signal conditioning and pre amp section as power supply. thanks for the common mode choke thing, u r right, I am driving the output fets directly fron the HVIC.. But I still need something to start with. can you tell me how the bootstrp cap and which diodes to you for fast charge ups?? this IC suffers from bad glitched power supplies, erratic behaviour at turn on. If i can get a circuit diagram or any applicaition note having a schematics using ir2110, it will be splendid.. |
#7 |
Hello Charles,
I dont know how to bias/use IR2110 for single supply H bridge operation. Could you please help or guide me. I have already tried through enough app notes. Got completely confused now.... Please help |
#8 |
One thing has already been mentioned: The ICs have to be fed with around 15 volts. The high-side driver is fed via a bootstrap capacitor. It is important that both ICs have their own bootstrap circuit. To say it in other words: A bridge application is the same as two standalone single-ended driver/output stages.
The spaciality is just that their inputs are driven with different phase and the load is connected accross both outputs. Best is you make a sketch of what you intend to do and we will be able to correct it. Regards Charles BTW: What do you mean by BIAS ? |
#9 |
Hope this will clear everything ?
SivanandBalan |
#10 | |
By BIAS i meant how should I connect the power to the MGD for correct /required operation. I hope, i didnt use this word at a wrong place. Please find attached is the circuit diagram for your reference. IN+ and IN- signals are taken from a balanced current modulator. Triangular wave is generated by integrating a square wave from a 555 timer configured for 400Khz frequency for full range front channels. though a costly option, I wanted to use N and P channel Mosfets for simple design. I am open to experienced recommendation on using N channels for high side using a 7404/7414 to invert the signal. I am also not quite sure about the compatibilty of the IR2110 for TTL level signals. Please advice. since this is a stackable design (output stages can be paralleled to the PWM signal) I plan to keep it the DSP section and mother board seperate from the output stage. using shielded cable the IN+ and IN- signals will drive the secondary output boards. I hope, I have conveyed the whole picture. Please comment.... |
| how ir2110 drives the high side mosfet in h bridge | gowri | Class D | 2 | 10th April 2008 06:30 AM |
| Power MOSFET class AB biasing | ingrast | Solid State | 29 | 4th February 2005 05:45 PM |
| confused on mosfet biasing!!!!! | AudioGeek | Pass Labs | 4 | 19th July 2004 09:50 PM |
| biasing a mosfet? | AudioGeek | Solid State | 2 | 17th July 2004 06:21 AM |
| Page generated in 0.12532 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
