| Class D Switching Power Amplifiers and Power D/A conversion |
#61 |
I got the 63v 22uf caps from Digikey today and soldered them into two of the modules.
CAP 22UF 63V ELECT VR RADIAL 2MM LEAD SPACING 5MM DIAMETER Digikey P/N 493-1121-ND MFG P/N UVR1J220MDD ...if anybody needs that data. The good news is that both of them fired up and ran perfectly - well, almost... Both amps trigger the DC protect circuit on the power supply (ST) and shut it down if the DC protect wire is connected from output(+) to the protect lug on the power supply. With out the wires the power supply relay does not trip and the amps run fine. The protext wires are wired correctly amp1->lug1 / amp2->lug2. The binding posts are plastic and completely insulated from the chassis and there is no evident short between (+) and (-) on either side. Why would this happen? Is it dangerous to run this way? In any case the group knowledge gained here is that it is possible to repair the UcD180 in the case of popped snubbers. Just to better focus the cause in my particular case I wired the power supply to the amp outputs which popped the caps. It was stupid but appears to be a survivable event. A muted Yippeee escapes my smiling lips... Regards, Tom |
| New UcD180 & 400 HG | Jan-Peter | Vendor's Bazaar | 29 | 26th June 2010 01:17 PM |
| UCD180 st or UCD180 hd ? | Davy | Class D | 10 | 5th August 2008 06:30 PM |
| UcD180 | Jonasz | Class D | 2 | 28th July 2005 11:16 AM |
| UCD180 Vs Others | jkeny | Class D | 21 | 18th October 2004 11:18 PM |
| Page generated in 0.07582 seconds (65.53% PHP - 34.47% MySQL) with 11 queries |
