SFX Class D subwoofer amplifier modification
Old 16th June 2006, 05:29 PM   #1
sagarverma is offline sagarverma  India
sagarverma's Avatar
Default SFX Class D subwoofer amplifier modification
I have been sifting thru this forum for a simple Class D amplifierwhen i stumbled upon the fact that this
Class D amplifier has been constructed by SFX for his sub.
what i want is to make it a dual supply version,is it possible?
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 16th June 2006, 06:48 PM   #2
Tekko is offline Tekko
Banned
Why not keep it as is ?
Old 17th June 2006, 04:25 AM   #3
sagarverma's Avatar
actually i want to use that amp in my car.i have a smps in the car giving output as + - V. I will be replacing TDA729x amps in the car bec they are big(mostly bec of heatsink).
so i want the amp to be able to hook up directly to the smps without unnecessarily straining it
moreover,isnt a dual supply version better than the single supply one?
can anyone suggest the requisite changes?
Old 17th June 2006, 05:22 PM   #4
sagarverma's Avatar
at least..can anyone check the schematic given at the website and tell wether its correct or not?
Old 17th June 2006, 07:18 PM   #5
Genomerics is offline Genomerics  United Kingdom
Account Disabled
It's not Buy One Get One Free.
What would you do?
DNA
Old 17th June 2006, 07:55 PM   #6
sagarverma's Avatar
i want to make a class d amp,dual supply one.
this one is too simple and so attracts me.
the other one is complex but promises good quality.
i will finish this one and come to that pretty soon(provided this one is correct)
can anyone check it for errors?
Old 20th June 2006, 04:12 PM   #7
sagarverma's Avatar
isn't there even a single person who can check this scheme for errors??
Old 20th June 2006, 04:37 PM   #8
Banned
You could check this:
Its my contribution on making the TB a split supply version, but it may not work, the pwm works, thats tested in simulator, but the power part i dunno.
Old 20th June 2006, 05:10 PM   #9
sagarverma's Avatar
hi Tekko,
thank u for your reply.
BTW,is the single supply schematic correct....if i go with that only then is that safe....?
power part....hw can that be corrected(tested) in your version?
Old 20th June 2006, 05:17 PM   #10
Banned
I have simulated the pulsewith modulator, tho the triangle was more of a sine it seemed to work.
But iīd still rdcommend you to build the thunderball after the original schem from the author. If you wanna build a split supply amp, try Titanchenīs circuit.
SFX Class D subwoofer amplifier modificationHide this!Advertise here!
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 30 23rd February 2018 02:54 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Filterless subwoofer Class-D amp Workhorse Class D 11 13th March 2009 08:11 PM
Class D & REL Subwoofer Stoatgobbler Class D 5 23rd January 2009 09:38 PM
