| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
i use a Y-splitter before but have modded the rca's by connecting them in parallel now.
i'm not an audiophile but in my amateur ears charlize is better and a bit powerful than SI.
noob on the block |
#22 | |
noob on the block |
#23 | |
I have bought a replacement t-amp, but I am now waiting on a Charlize amp to arrive in the post, as well as a tubalizer. I am thinking that I will use the Charlize on my main system in the box I intended for the SI t-amp mods, using the tubalizer as a buffer between my phono pre-amp/line selector (a cheap TC-754, its great!) and the charlize. I am also new to audiophile (but not to audio, been an audio engineer for a long time now) so this is all very much great fun! |
#24 | |
Yes they are, that is why L1 & L2 are removed. It is easier to solder to the bridged pads. |
#25 | |
decided to proceed with stealth mod 2 and was successful using only a 1uF/50v ELNA elec cap found in my parts bin. i was just assuming that this cap is better than the 0.33uF stock cap. the result wasn't bad. but i did not listen to it for a long time (in full mode) as i have to use it back on the tweeters. hurray my SI amp is alive and kicking again ![]() thanks again guys for your help.
noob on the block |
| Fried T-Amp? | Bingobing | Class D | 11 | 2nd November 2010 02:12 AM |
| Fried New Amp | memito | Car Audio | 8 | 10th August 2004 01:38 AM |
| I think I fried an amp | mashaffer | Car Audio | 1 | 20th July 2004 12:54 AM |
| $5 SE amp... but is it fried?! | SHiFTY | Tubes / Valves | 3 | 18th January 2004 03:13 PM |
| Page generated in 0.08285 seconds (78.23% PHP - 21.77% MySQL) with 11 queries |
