bridging ucd amps
bridging ucd amps
Old 5th June 2006, 04:46 PM   #11
guyv is offline guyv
I have to correct my statement: "In your case the load will look like 1.5 ohms so 1.5x10x10 ". Each amp "sees" a 1.5 ohm load and so tries to deliver more current but the delivered power is still 3x10x10 so 300watts so double what I had stated. So bridging does give you more power due to the wonderful specs of the UcD.
The only caveat is that you are getting close to the 1 ohm lower load limit for the UcD. You might also want to check the power and current limits for your driver so that you don't risk burning it. A stated before a single UcD180 might be enough.
Old 5th June 2006, 04:56 PM   #12
-CGL- is offline -CGL-  Finland
I tested two 180īs bridged. 440W @ 8R +/- 49V rails. I had two 100nF caps in series between the outputs.
Old 5th June 2006, 08:05 PM   #13
Ric Schultz is offline Ric Schultz  United States
Can you test them at 4, 3 and 2 ohms? This is where the current limiting will show. Thanks.
Old 6th June 2006, 05:45 AM   #14
The pair started to limit well before 440W. 440W was the "audible" clip point. It was hooked up to an AP, and monitored with an O-scope, the point where the distortion started to increse, showed on the oscillogram as well. The I limit is somewhere between 9-10Ap.
bridging ucd ampsHide this!Advertise here!
Bridging Stereo Amps 375 Tubes / Valves 9 12th August 2007 06:29 PM
Bridging many op amps Bazukaz Chip Amps 12 25th January 2006 07:47 PM
bridging two amps x4 power ? djdamix Solid State 6 17th December 2004 03:27 PM
bridging amps? mikee12345 Multi-Way 4 24th March 2003 03:08 AM
Bridging amps hacknet Solid State 17 12th December 2002 02:16 PM
