| Class D Switching Power Amplifiers and Power D/A conversion |
Hy guys,
I can hardly wait for my T-Amp, my Marantz PM7200 needs repairing and will be back in about 2 weeks, and I took the oportunity to try out an order the Sonic Impact at last. My curiosity grows every time I read some rave comments of this little thing, and I'm already planning to offer it a metal case, alps poti, rcas and so on. Reading the promising reviews I ask myself which part of the T-Amp is so great, the input or the output stage ? This is important to me because I think about using the T-Amp a a power amplifier and hook it up to maybe a Rotel preamp, in order to get tone controls, remote control etc. But I don't know whether that would be a good idea, because so far I believe the T-Amps strength lies in its simplicity, and I wouldn't like to mess up the signal with an usual preamp. That would be the case if the t-amps strenght would be the preamp section. So what do you think about using a good quality rotel or so preamp with the t-amp ? Greetings, Chris |
#2 |
Oh, by the way, speakers are T+A Stratos F1 2-way bookshelf speakers on arcus stands, rated at 90db and 4 ohms. I guess they will work pretty well with the t-amp...don't you ?
#3 |
the stock t-amp is a bit bass shy
i have mine modded with stealth as suggested in http://www.michael.mardis.com/sonic/start.html a good power supply is a must to achieve good sound at this moment the t-amp is being used as an integrated amp for bedroom listening i have tried using it as a power amp by maxing the volume and hook up with a pio elite 7.1 ht receiver driving the front L and R bookshelf 2 way speakers with 8" mid/bass. the result is very good. ![]()
#4 |
I'm also planning to apply the stealth mod to my t-amp, for that I just ordered 2x Mundorf-MCap 2,20 uF 400V, 3%. Those are made for crossover building, but I suppose them to work, or did I miss something ?
Does the stealth mod improve bass performance ? @cpu 8088: I would love to see your t-amps interior ! So far I pretty much know what to do, but I still have one question about the power supply. I'm planning to use the t-amp with a regulated voltcraft 13,8V 4A psu, but don't know how to connect the psu to the t-amp. Should I use an adapter and connect it directly to the psu connector on the t-amp, or should I take those cables leading to the batteries an put some adapters on them and connect those with the 2 cables from the voltcraft ? thx |
#5 | |
This jumper gives a more direct, lower resistance path from the PSU to the supply rail.
Take the Speaker Voltage Test! |
#6 |
Thanks a lot for the advice and the picture, if I got that right you would suggest to apply the stealth mode AND exchange the onboard input caps with better ones ? That would make 4 caps...right ?
And what about the power supply, are 2A sufficient or should I go for the 4A Voltcraft psu ? I have a 12V 0,8A switching psu around here, that would fit with the t-amps psu connector, but I know that its underpowered with only 0,8 A and my question is if that would damage the t-amp ? Sorry bout so many stupid questions, this is my first diy project, gotta learn... Greetings |
#7 |
inside my modded t-amp is a mess and no exotic replacement caps either.
i am no good diyer just a newbie. i only followed pana's great advice and ideas regarding power supply i am using a 12v 2a regulated one. i have modded the input to use a solid xlr type connection which you can see at the back of the case. if you can find a 12vdc 5a power supply that would be ideal. beware of flimsy power supplies stated as 12vdc but actually higher. that would fry your t-amp definitely the stealth mod improve bass. check measurements in michael mardis website next stage for me is to have another mod t-amp as power amp for home theatre front LR speakers |
#8 |
You will need 3 caps. 2 for the inputs (left-right) and one electrolytic onboard.
A 2 amp power supply will probably be enough if your speakers are 8 ohms. During most music the amps draws about 0.3A But loud passages will draw much more. 3 amps seems to be plenty at 12V. Most regulated supplies will give you a brief burst of much more current than rated. How much and how well depends on the supply. A lower current rating will not hurt anything - except the bass. ![]() Be sure you get a regulated supply. Stay at 12 volts unless you add cooling to the chip. The XLR used by cpu8088 makes a very nice power connector. A cheaper and easier connector is a 1/4" phone jack.
#9 |
Hy guys,
please take a look at this modded t-amp: http://www.yurigagarin.ch/lazy-index.php?file=Baikonur/ The guy managed to include a source selector... Great ! |
#10 |
Nice box! Not crazy about the wiring though....
So that 's what Youri is doing now that he is retired from being 1st man in space. I wonder if Laika helped him....
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.12190 seconds (78.17% PHP - 21.83% MySQL) with 11 queries |
