| Class D Switching Power Amplifiers and Power D/A conversion |
After turning my amp6 on it's silent, but after 5-10 minutes of playing music I get a lot of noise coming from the left speaker. Its crackles and pops mostly. Also, if I move either set of speaker wires a little (from board to the binding posts), the right speaker cuts out. Doesn't matter if I move the left wires, or right.
Any Ideas, maybe I can ground something? When I had a t-amp setup in the same case, it was dead silent. Heres a pic of the amp6 |
#2 |
someones gotta know
#3 |
You probabaly have a bad solder on one of the left speaker lines. Certainly isn't a short to the case, 'cause it's wood!
Check your soldering, see if you can find exactly were moving the wires causes the problem. Your trouble will likely be there. Also: Please use shielded wire for your inputs! Whatever you can get will be better than bare wire.
Take the Speaker Voltage Test! |
#4 |
Thanks pano, a little extra solder fixed the cutting out...not sure about the noisy left channel yet though. Do you have any recommendations on insulated wire? Im thinking of this stuff from ebay:
http://cgi.ebay.com/50-ft-22-AWG-Sil...QQcmdZViewItem Thanks again! |
| Some Thoughts on I/O of Amp6 Kit | CLS | Class D | 8 | 24th May 2010 02:48 AM |
| TA 10.1 or Amp6 or something else? | aquapiranha | Class D | 11 | 19th February 2009 07:45 PM |
| Charlize or Amp6 | spadulata | Class D | 1 | 5th July 2006 08:39 AM |
| noisy noisy noisy noisy noisy tube | dsavitsk | Tubes / Valves | 50 | 20th February 2006 04:07 PM |
| Page generated in 0.07814 seconds (68.33% PHP - 31.67% MySQL) with 11 queries |
