| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
Classd4sure,
Thanks for the feedback. I bought the UdC-180, built two mono blocks, and they have been performing great with thier +/-47 volt supplies. Now that I have cleared that hurdle, I may work on improving the filtering in the PS. I would like to add chokes, but haven found a sutible e-core chock for the job. They would also drpo the PS voltage down a tad. Thanks again. Cheers, Ray |
#12 |
Sorry Chris, but UCD180's that have been shipped have STPF14NF10P mosfets installed and these ARE 100v, 15 amp, 15nc, 0.13R FETs.
Run them at +/-48v and see them smoke! Steve |
#13 | |
Regards, Jan-Peter |
#14 |
Hi all,
I just bought a pair of UCD 180s. I had 4pieces of 80VA, 35V toroids hanging around. I wound off 83 turns on each to reach about 32V at high line and 5W load. Since I have not connected the scope yet to quantify the ringing on edges if any, I wouln´t sleep well with higher voltages. But if the FETs can take 120V then....Well, I will not Re-wind.... / Mattias |
#15 |
#16 |
Don't want to be down on the Hypex modules as I have used them in my own amp projects both Ucd180 and UcD400 and they are excellent.
I recently built an amp with one of the ConnexElectronics Tripath TA3020 boards using a power supply that I had built for a UcD180. It worked a charm and being a stereo module is much cheaper, a serious contender. Also, the TA3020 can take between 40v-62v So your 48v would be perfect. see my website (url below). ConnexElectronics website: http://connexelectronic.com/product_...7cncvg2bn7qj31 CNX also has a thread in venders bazaar: NEW Audio amplifier kits, modules and many others. col.
http://www.minirig.org.au |
#17 | |
How does this amp compare with the Hypex ucd400's? I am very interested in the Hypex but the cost is much higher than the amps on Connexelectronic. Sometimes, you get what you pay for though. |
#18 |
I find it comparable to the UcD180, I am running it off the same kind of power supply. Don't know about comparing it too the UcD400 that would require me to beef up my power supply.
col.
| Dual supply for LM1875 split supply | dovganj | Power Supplies | 30 | 6th November 2009 03:19 AM |
| Boost controller for +48VDC? | LukasLouw | Power Supplies | 2 | 11th February 2009 02:27 PM |
| 3 Pin regulated supply VS zener based supply | KevinLee | Solid State | 3 | 15th September 2008 02:40 PM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
