Go Back   Home > Forums > Amplifiers > Class D
Old 14th May 2006, 06:22 PM   #1
jwb009 is offline jwb009  United States
Default Amp 6 and SMPS
Not knowing too much about electronics, I want to make sure I have everything correct before testing my amp6. I'm going to use a 12v smps and want to make sure I left the right components off the amp6 board. They are as follows:
R100 Voltage regulator set Resistor
R101 same
R102 same
Q3 LM1084 Voltage Regulator
CMP15 PS rectifier
C99 Bulk Capacitor
C102 Voltage Regulator decoupling
Am I correct in leaving those off? Any help is appreciated
Old 14th May 2006, 08:38 PM   #2
Anyone? I'm really just not sure what to do. I'm guessing I can install the big cap, but i'm not sure about the resistors, or the rectifier?
Old 14th May 2006, 10:40 PM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
I don't have an amp6 but those sound like the components needed to make a standard regulator circuit.
Brian
Old 15th May 2006, 12:40 AM   #4
hmm, excuse the ignorance, but would that be a yea or nay for installing them?
Old 15th May 2006, 04:33 AM   #5
Don't install them if you're going to use a 12-14V SMPS as the power supply. If you want to use a higher voltage (greater than about 17V depending on the dropout voltage of the onboard linear regulator) SMPS or any other higher voltage DC supply you can install all the parts but the rectifier and use the onboard regulator to regulate the higher voltage down to 14V.
Brian
Old 15th May 2006, 12:22 PM   #6
thanks!
Old 15th May 2006, 09:04 PM   #7
Pano is offline Pano  United States
Pano's Avatar
Leave C99 on, it will help. You may have to put a jumper or 2 in place. I'll check on that.
**** Yes, you'll need at least one jumper. Since you do not have the volatge regulator, you'll need a jumper in its place. Put a jumper between the 2 legs that are nearest the end of the board where the power comes in.
You will see that the hole nearest the power end of the PCB goes to + on C99. You want that one and the middle hole.
You can bring power onto the board via the "GND" connection and the + terminal of C99. Be SURE to check and double, triple check you polarity. If you get it wrong, you'll fry the chip.
Let us know how it goes.
Take the Speaker Voltage Test!
Old 16th May 2006, 01:27 AM   #8
awesome, you guys rock. The amp is singin!
Smps a2005r2003 Power Supplies 19 11th August 2011 06:19 AM
SMPS for B+ from PC PS jkeny Tubes / Valves 1 10th February 2007 07:52 PM
Smps Juani_12-5 Car Audio 8 20th January 2007 09:15 AM
Smps rinox Power Supplies 0 2nd September 2005 10:05 PM
Need help on car SMPS DFI Car Audio 16 18th June 2004 05:59 AM
Page generated in 0.08850 seconds (75.35% PHP - 24.65% MySQL) with 10 queries
