Go Back   Home > Forums > Amplifiers > Class D
Old 15th May 2006, 07:46 AM   #11
Puffin is offline Puffin  United Kingdom
I have just made a switch mode power supply 12v 3A. I got the board off e-bay for £4.75p. If you can use a multimeter then it is very easy to out together your own. This one accepted any mains voltage between 115v and 250v. I have added some smooting caps (6,800 x2 in parallel) and it sounds good.. Like the best of batteries and regulated power supply combined. No noise either.
Old 15th May 2006, 08:01 AM   #12
Lostcause's Avatar
Interesting, which board was that Puffin?
Old 15th May 2006, 10:17 AM   #13
Artesyn NFS40-7612. He had 4 of them. They are still being offered for sale.
Old 15th May 2006, 06:30 PM   #14
cpemma is offline cpemma  United Kingdom
Originally posted by entropy0
[B]I was thinking of using a small heatsink for a computer chip that I have in my parts box, for the chip in the SI. I'm sure that would work well, but.... how to adhere it to the chip?
My research indicates most superglue is good to 85C and should allow a thin glue-line; I'll be trying it unless somebody warns me off it...
Old 15th May 2006, 09:02 PM   #15
Pano is offline Pano  United States
Pano's Avatar
In the USA, have a look at surplus electronic resellers. You should be able to find a SMPS fo under $10, easy. Get 12V. At least 2 amps. They can be very quiet if you add a cap or 2.
As for heat sinks, just get one from "WLUK" on ebay. It's a RAMDAC sink.
Take the Speaker Voltage Test!
Old 15th May 2006, 10:39 PM   #16
I already have a heatsink as pictured on the ebay page. I'm sure not sure how to adhere it to the Tripath chip without eliminating or seriously reducing the heat transfer between the chip and the heatsink.
As for the SMPS, I'd really like to use what I already have as well, which is a PC power supply. I don't know how many amps they put out but according to some who have modified a PC PSU to work with their chip amps, they can sound really good with the SI amp. With my limited electrical background, I'm currently trying to figure out how to modify one of these things to work with the Sonic Impact....
Old 15th May 2006, 11:07 PM   #17
theAnonymous1's Avatar
I have the cheapest miracle cure for your heatsink adherence problems. JB Weld. Its a metal filled 2 part epoxy that can be found at almost any auto parts store. I have used it countless times for heatsinks. It has fairly good thermal properties and can handle up to around 500 degrees Fahrenheit.
They make a quick set version but I have personally never used it. The regular stuff takes a few hours to setup all the way. If you turned the amp on while it was setting the heat from the chip will speed things up a bit.
I STRONGLY recommend against super glue. It melts rather easily.
The little heatsinks "WLUK" sells on ebay are great, but the adhesive tape deosn't stick to well sometimes. I would recommend removing the tape and using JB Weld instead.
Old 16th May 2006, 03:59 AM   #18
Pano's Avatar
The WLUK heat sinks come with "Frag Tape" but theAnonymous1 is correct, it doesn't stick very well. Press hard when you put it on. Also, clean the chip before you stick it. The JB Weld solution I have not tried, but it sounds like "cool" idea.
Old 28th May 2006, 07:46 PM   #19
Whoah. Don't use hot glue or super-glue.
Use what computer modders use, a specially designed thermal adhesive. They're glue with metal particles in them so that they transfer heat better between your sink s and chips.
Any decent computer store should be able to sell you something.
http://www.newegg.com/ProductSort/Su...SubCategory=85
Also, there is a wealth of information out on the web about how to properly apply this stuff.
Old 28th May 2006, 08:06 PM   #20
Send a message via MSN to DoomPixie
yup.. thermal epoxy, arctic silver makes a nice one, personally i mix a little extra arctic silver thermal paste into it incase i ever want to remove the heatsink.. it is rather permanent otherwise, but if you mix a little arctic silver thermal paste in it makes it a little softer.. works really well imo...
Owen
FS: Sonic Impact T-Amp oldman1 Swap Meet 2 6th December 2007 06:53 PM
Sonic Impact for MI amp mashaffer Class D 1 21st February 2007 08:25 PM
Op-Amp Pre for Sonic Impact? Buckapound Class D 11 21st August 2006 09:42 PM
sonic impact t-amp in car? ractis Class D 13 25th February 2006 04:44 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
Page generated in 0.11027 seconds (81.33% PHP - 18.67% MySQL) with 10 queries
