Hypex UcD400 reviewed - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th May 2006, 08:06 PM   #11
Bgt is offline Bgt  Netherlands
Originally posted by Jan-Peter
Besides this we hardly find any influence when the amps are mounted very close to each other. However you WILL have problems when you are wiring the amplifiers in the WRONG way.
endless discussion
Kind regards,
Bert
Old 10th May 2006, 08:06 PM   #12
Originally posted by Eva
Are you performing conducted and radiated EMI measurements on signal, speaker and power wires? Will you use any kind of common mode filtering to match SMPS "quietness" industry standards? That's important because any RF component radiated by wirings will be dependent on the audio signal, and it will be demodulated and turned into audio when picked up by other circuits.
By the way, one trick of which I'm taking advantage in high power class D is to use two series inductors laid in a dipole fashion. That produces inherent stray flux cancellation in the far field.
The EMI performance of the UcD amplifiers is very low. Meets easy all standards. We do not use extra common mode filtering.
Our new OEM version (dual UcD180 on one PCB), is having such a low EMI in the 70-110MHz area that these amp can be build together with an internal FM tuner.
Jan-Peter
Old 10th May 2006, 09:07 PM   #13
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by Jan-Peter [/i]
The purpose of this demo amp was to show how small you can build an UcD amplifier. And it's easier for reviewers to measure on a complete working amplifier, as on separate modules with transformers and power supplies.
The reviewers were greatful to have a working amp. They were also quite pleased, not as skeptical as when they tested one of your competitors (I'm sure you know who).
We have on our website soem recommondations for wiring.
This will save a lot of grief and in particular for the builders. Wiring is not obvoius for a "normal" person and correct wiring is _very_ important if you want to take full advantage of the modules. Compare all gainclone builder with not so good wiring directions. Most problems there is hum problems due to uncorrect wiring. Don't forget to make a sketch for stereo and one transformer.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 11th May 2006, 07:44 AM   #14
Correct wiring is of utmost importance but there is no golden rule what's best for any situation. You need a proper wiring scheme that will satisfy the basic needs but than there is the fine tuning, even if it changes the whole basics of the scheme, and here the differences are more present when done right for that situation.
Kind regards,
Bert
Old 11th May 2006, 07:55 AM   #15
Some of our new OEM version;
http://www.hypex.nl/UcD182.jpg
http://www.hypex.nl/UcD402.jpg
You can see that the cols are quite near mounted to each other. We do not measure any real influence between the two amps.
I am hihly looking forward to the English translation of the Danish review!
Jan-Peter
Old 11th May 2006, 01:06 PM   #16
@Jan-Peter: Will these little beauties be availeable to non-OEM customers in the near future?? Please??
Nils
Old 11th May 2006, 01:15 PM   #17
No, I am sorry these are only for OEM customers. The UcD402 is used in our soon-to-be-released 800W subwoofer plate amp. And is used in a www.hevos.nl Bassgitar amplifier.
However there is not really a new thing. With two UcD180 you have one UcD182, and with two UcD400 you have one UcD402.
I am glad you like them.....
Jan-Peter
Old 15th May 2006, 09:28 AM   #18
peranders's Avatar
Half of the article is translated...
http://sjostromaudio.com/smf/index.p...5.msg716<br />
Old 15th May 2006, 10:21 AM   #19
Banned
Eeeek You put it on the driveway to take the pic What if someone had stepped on it.
Old 15th May 2006, 02:19 PM   #20
peranders's Avatar
The translation is ready now and I'll hope you can understand something.
How can I recognize an Hypex UCD400 from an UCD180? zigo3 Class D 6 25th March 2009 10:53 PM
f/s hypex ucd400 hg with onboard hxr regs slr 5000 Swap Meet 8 17th March 2009 10:26 AM
Hypex UcD400 HG Monos for sale sbrtoy Swap Meet 10 29th June 2008 12:30 PM
My hypex UcD400 based amp dagoose Class D 3 27th May 2008 05:00 PM
Hypex UcD400 3-channel $1,200 Al Garay Swap Meet 1 10th November 2005 05:49 AM
Copyright ©1999-2017 diyAudio
