| Class D Switching Power Amplifiers and Power D/A conversion |
Hi, I was hoping if some one could tell me if I am on the right track. I want to build a 12V battery operated power supply for the TA2022 (Fenice 100 specifically). I want to use the LM2577 Step-up Voltage Regulator set for 31V and delivering about 1.6A. I want to use 2 LM2577s, hooked together, to give me the +31V/0V/-31V to run the amp. I calculate the max current I can get from the supplies is 1.6A. My questions are:
1) Is 1.6A enough to get the full 200W out of this amp, or am I really only looking at 1.6A * 31V * 93%(amp eff) = 47W? 2) Can I hook the (+) of one regulator to the (-) of the other in order to get the Pgnd needed? In the thread "AudioDigit's new 100W T-Amps", holdent wrote: ..."{AudioDigit} also indicated that any power supply that could provide more than 1A was fine" for the TAA4100A. Am I way under powered? THANKS TO ALL. |
#2 |
1.6A will be enough for normal music signals played below clipping level.
Also, consider a transformer-coupled push-pull converter as the ones used in car amplifiers, fed from the batteries either connected in series or parallel. However, note that non-bridged class D amplifiers also return current to the supply rails, and you have to find a way in which your PSU could handle that.
I use to feel like the small child in The Emperor's New Clothes tale
#3 |
Thanks for the reply Eva. I built the pair of PS and hooked them together as planned and no smoke. I am going to have a friend at work help me check the regulation. I have the option to run the supplys off 12V instead of 24V (as in my original post), which would give me the +31V/0/-31V but only at 0.8A.
Can I still get the full 2x100W at this amperage? Is the current usage info on the spec sheet? I looked but cannot find anything like this. Thank you again. |
| Q about Total power dissipation | Bensen | Everything Else | 8 | 29th December 2005 10:02 AM |
| calculating total power in PA systems | Disney_SK | Solid State | 11 | 16th June 2005 10:46 AM |
| TA2022 power supply | simingx | Class D | 1 | 22nd March 2005 12:36 PM |
| Oscillations-total newbie question | fragman56 | Tubes / Valves | 4 | 23rd April 2003 05:12 PM |
| Simple question. Total speaker impedence. | JoeBob | Multi-Way | 6 | 6th November 2001 06:42 PM |
| Page generated in 0.10007 seconds (67.45% PHP - 32.55% MySQL) with 11 queries |
