| Class D Switching Power Amplifiers and Power D/A conversion |
I have an Audiodigit Tripath 2020 based amp that is up and working well. Sounds wonderful. I mainly listen to it via AKG K1000 headphones. Last weekend I decided to check the DC offset on the output. One channel was 0 but the other channel was about 65mv. Is that anything to be concerned about in terms of damaging my phones or other speakers? Thanks a lot, Paul |
#2 |
65mA is a perfectly acceptable offset for an audio amplifier. It will cause only a few mA of current to flow and no damage.
#3 |
Headphones don't work well with the Tripath chips except the K100s.
You should still put an 8 or 6 ohm resistor across the speaker terminals so that the output filter will work properly. It will also help drop the ultasonics going to the AKGs.
Take the Speaker Voltage Test! |
#4 | ||
#5 |
Why don't you use the trimmer in your Tripath board to control the DC Offset ?
If you want power you must add control |
#6 | |
http://www.autocostruire.com/catalog...roducts_id=257 I would be happy to be wrong Best, Paul |
#7 |
diyAudio Moderator Emeritus
They don't come with an offset trimmer but you can wire up one up for each channel with two 10kohm pots, two 1Mohm resistors, and two 0.1uF caps. My Ref-T boards have provisions for the DC offset trimmer circuit
![]() There's a schematic of how to do it in one of the Tripath datasheets. Can't remember which one though.
Brian |
#8 |
I don't think that voltage offset is enough to do anything either, IMO with its 120ohm impedance and pretty low sensitivity the k1000 is less susceptible to DC offset than most other things, perhaps less sensitive than some of the smaller high efficiency speaker drivers ???
But why I posted was that A couple of people have had problems with the k1000's dying with t-amps... so I was wondering if the tripath ultrasonics could damage a 120ohm driver if youre not using the parallel resistor? Although we can only guess at the k1000's impedance at these frequencies, I'm sure a few of you know more about the ultrasonics a t-amp puts out than I do... Could they put out enough ultrasonics to kill a high impedance driver? I would sure like an explanation as to these dying k1000's, considering i have a k1000 and a Charlize in the mail. |
#9 |
Here's a scan regarding amplifier to headphone connection:
Deep down inside. |
#10 |
I don't know why there is such a rush to use the T-amps with headphones. Because it's cheap? Really, there are better amps out their for headphone use.
As for ultrasonics, there is quite a bit left over in the signal. I have only measured one set of tweeters at 700kHz, but they were about 16 ohms. 4 ohms at normal frequencies. No idea what the K1000 do. The T-amps NEED a resistor on the output if you're going to drive headphones. 8 or 6 ohms would be ideal. This load helps the output filter. See this graph. The line that heads for the sky at the top end is the unloaded response. That's what you'll get on headphones without that resistor. The image lucpes posted above is close to what I use for my amp testing headphone rig. An L-Pad. But use 8 ohms, not 20, as seen on the drawing.
| Tripath T-Amp | john65b | Swap Meet | 10 | 25th September 2010 08:59 PM |
| Why Tripath? | Davey T | Class D | 4 | 25th May 2009 09:14 PM |
| ICE vs UCD vs TriPath | JimOfOakCreek | Class D | 6 | 26th March 2008 11:26 PM |
| Page generated in 0.11203 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
