Go Back   Home > Forums > Amplifiers > Class D
Old 20th April 2006, 05:03 PM   #1
irss is offline irss  Lithuania
Question Modded T-amp dislikes CD player. Why?
My system is:
- modded T-amp - audyn 2.2uF caps, fast elna silmic cap on the board, big cap off the board, ALPS 50k pot, quality rca and speaker plugs.
- nad c521bee CD player.
- 88dB sensitivity speakers.
strangely, the T-amp sounds great with any CD player, except my NAD. With NAD it lacks bass, the sound seems to be flat and tiring. However, the same CD player (NAD) sounds good with other solid state amplifiers (technics, rotel) with the same speakers I have. Consequently, it appears that T-amp does not like my NAD.
I still cannot figure out what could be the problem...why t-amp 'hates' my dear NAD CD player
guys, any ideas how could I fix the problem? or should I start looking for other CD player?
I've read that Monica II (NOS DAC) is a good friend of t-amp, but would it solve the problem...
i would really appreciate your help
Old 20th April 2006, 06:53 PM   #2
GJF is offline GJF  United Kingdom
Which input mod have you performed?
Do the 2.2mf Audyn caps replace the on board surface mount or have you removed some of the other input components?
I have found that the wiring required for installing off-board input caps can help induce noise into the input stage negating some of the benifits of changing, others disagree but the input filter on these amps is there for a purpose.
If it helps any I have an Amp3 thats fine with everything connected to it and an Amp 6 that loaths my Sony Cd player with which it sounds somewhat thin and strident when the same player is smooth and powerfull through the Amp 3!
Old 20th April 2006, 08:43 PM   #3
GJF, the mod was done according to the 'stealth mod' on the panomaniac web.
Old 21st April 2006, 11:38 AM   #4
Pano is offline Pano  United States
Pano's Avatar
Hmmm....
Sounds like an input impedance problem. As if the NAD doesn't have enough current to drive your modified Sonic. But with the stealth mod you should have a pretty high input impedance. You did remove R01/R02, right? It wouldn't work otherwise.
Do you have an active preamp or line driver that you can put between the NAD and the Sonic? Something to act as a buffer and add a little drive? If it brings back the bass, it's an impedance problem.
Take the Speaker Voltage Test!
Old 21st April 2006, 12:20 PM   #5
Pano, yes R01/R02 were removed. I'm not using an active preamp or line driver. Probably I should try one...
Although comparing to other CD players, NAD player plays pretty loud.
Old 21st April 2006, 04:47 PM   #6
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Try a 47pf cap or so to ground at the input.
Deep down inside.
Old 21st April 2006, 07:55 PM   #7
cpemma is offline cpemma  United Kingdom
NAD - "The output impedance is very low at 300 ohms, making the NAD C521BEE less sensitive to cables or the ancillary equipment it is partnered with."
My old NAD 5420 works fine with the 5066, that's 120 ohms, 2V RMS @0dB
Old 22nd April 2006, 05:48 AM   #8
Pano's Avatar
Well, that should be plenty to drive the Sonic. So I don't know what the problem is.
If you do get a chance to put an active preamp or line stage in there, please try it and let us know.
Old 24th April 2006, 04:12 AM   #9
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Output impadance, source impedance, and load impedance capabilities are sometimes mixed in the terminology.
Hear the real thing!
193L in a Modded DAC-AH.. JandG Digital Source 49 27th December 2011 11:56 PM
FS: Modwright modded - Sony DVP-NS999ES SACD player $495 bbaker6212 Swap Meet 0 3rd October 2007 04:15 PM
FS:Samsung Hd-841 (modded) Universal Player mrdon Swap Meet 0 27th November 2006 06:49 PM
Modded BPA-200 Mattyo5 Chip Amps 13 30th November 2005 05:53 PM
My SI modded amp. TriodeGuy Class D 3 18th April 2005 01:17 PM
Page generated in 0.10985 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
