Help. I blew up my amps...
Old 13th April 2006, 11:52 PM   #1
ptwining is offline ptwining  United States
Default Help. I blew up my amps...
First let me say that the longer I read here the more I learn. Thanks to all you folks for the resource.
Anyway, awhile back I toasted two UCD180's by putting power to the outputs. I reversed the orientation of the boards and spaced out as I reconnected their existing harness. Power on - POP - smoke - a silent, imagined, tiny electronic scream as sudden death ensued...
+/- power connected to +/- speaker.
I blew the top off the cap labelled A in the picture - nuttin left but two metal leads and a plastic base.
Whatever it was inside that cap was spattered everywhere. It looked like tiny shreds of fibreglass.
Both amps blew the same cap - that is - on the right of the heatsink as shown in the picture. They did not blow the identical cap on the other side of the heat sink.
I am just a hobbyist wrt audio hardware and I'd be obliged if you could help me answer a couple of questions.
1). what did I blow up and what does it do?
2). Is it possible that that cap is all I blew?
3). Shall I solder it out and replace it just for grins, or is it hopeless?
4). If it isn't hopeless could someone tell me how I can specify a replacement? Kevin sent me to Digikey (for a 22MFD 63v cap) but the choices are mind-boggling. There's a bunch of different ones. Which one is right?
Jeez, I know all this sounds really lame but I'm honestly enjoying this and want to learn more.
Hey, at worst, I have a new career making smoke-bombs! (LOL)
Best Regards,
Tom
Old 14th April 2006, 10:14 AM   #2
classd4sure is offline classd4sure  Canada
Account Disabled
Help. I blew up my amps... Send a message via AIM to classd4sure Send a message via MSN to classd4sure
1-It's a high ESR electrolytic bypass cap used for snubbing the power rails.
2- Unlikely, since it's just a decoupling cap it would still work without it if nothing else was blown. Check for blackened components as a first step.
3. Hard to say, proceed with caution.
4. Look for other burnt components first.
Old 14th April 2006, 01:54 PM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
http://www.vishay.com/docs/28312/036rsp.pdf
The cap is a BC components 036 series 22uF 63V. Digi-key doesn't have that specific cap.
Mouser might have it, I don't feel like trying to search through their mess for you though
Brian
Old 14th April 2006, 03:43 PM   #4
classd4sure : Thanks for your answer :
On a close inspection of the board (top and bottom) I find no evidence of toasting - no flux runs - and no discoloration of components. It doesn't smell like burnt pcb either...
Would work without it? Hmmm. I didn't even try to run it after the pop. I powered down soooo fast.
Maybe a good meatball test would be to hook it up to my power supply and see if it works before ordering the caps? Might tell me if anything else if cooked. Unless it might fry the power supply?
bwrx :
Thanks for the ID on the cap and the heads-up on where to find it. Not to worry about finding it for me tho, I've got to learn this some time. Why not now?
Thanks both.
Best regards,
Tom
Old 15th April 2006, 01:34 AM   #5
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Tom:
After you solve this you may want to buy a variac for test purposes. I bought one, second hand, cheap... it surelly helped me many times as its fuse is the first to blow when things go wrong.
Unless this will be your last DIY project wich I doubt as this hobby is like a disease: a success leds you to another project and a frustrated one makes you hungry for revenge!
Good luck!!!
M
"Cascode all thy outputs".
Old 15th April 2006, 03:57 AM   #6
Default Thanx Max...
No, it certainly won't be the last - no antibiotic can cure me now!
I'd have to learn how to use the test equipment before I'd benefit, but hey, I'm willing.
It's hard to start off in this thing - so much to know - and too much to learn right off the bat.
I'm patient - what the hell - I might live another twenty years and get a shot at knowing what I'm talking about!
LOL
Best Regards,
Tom
Help. I blew up my amps...Hide this!Advertise here!
I think I blew up my t-amp...... help! tyler477 Class D 11 27th November 2008 01:34 AM
I blew up all my amps :irked: (Help needed, hafler adcom) Septimus Solid State 14 14th May 2008 12:05 PM
Fuse blew markiemrboo Chip Amps 30 21st November 2006 05:40 PM
Why older RF amps always blew up with DC in output valterdaw Car Audio 10 18th August 2006 03:15 AM
blew up a UCD400. Why did it die? mp006ltk Class D 11 14th July 2006 10:46 PM
Copyright ©1999-2017 diyAudio
