Go Back   Home > Forums > Amplifiers > Class D
Old 17th December 2007, 08:46 AM   #521
Gyula is offline Gyula  Hungary
Gyula's Avatar
Send a message via Yahoo to Gyula
Originally posted by Eva
Open loop digital systems are a big no-no, a stupid dead-end
Power Supply Rejection Ratio is 0dB in these systems!!
On the other hand, closed loop digital systems are equivalent to any analog-controlled class D amplifier, but requiring fast, precise and expensive ADCs instead of standard DACs, so they are another dead end.
Hi Eva!
How could you define the 0 dB PSRR with a full-bridged amp.?
Old 1st January 2008, 08:26 AM   #522
John Hope's Avatar
Default PowerDAC3 development
Hi all
I have several photos of prototypes and pcb version of my new PowerDAC3 digital amplifier power module that when zipped result in a file of around 1.8MB.
I'd like to post these on the forum but the 100K attachment limit poses a problem. I've tried reducing the image size or jpg quality of these images so that each is less than 100K, but I feel the loss of detail is too great. As you know, with things like this the devil is in the detail.
Does anyone have any ideas on how to work around this in some way that does not compromise image quality?
At Spes Infracta
Old 1st January 2008, 09:05 AM   #523
pinkmouse's Avatar
John, mail them to me and I'll have a look. I'll drop you a line so you have my email address.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st January 2008, 11:30 AM   #524
John Hope's Avatar
Here follow some photos of the PowerDAC3 prototype which I designed and built around 18 months ago, and first pcb version which I am presently testing.
Thanks to Al for compressing the pics for me without losing detail.
These show the single channel prototype OPS of the PowerDAC3 about halfway through development.
This scope photo shows the 3.3V PWM logic drive signal and the OPS switching waveform on the OPS phase node at Vdc = 15V. Signal integrity is preserved over the full Vdc range of 1-60V.
These show the single channel OPS of the PowerDAC3 in the final prototype configuration completed around 18 months ago and which was taken to pcb. The OPS is an open-loop full bridge using SMD power devices and was tested to 350W into 4 ohms, 175W into 8 ohms. THD+N was around the 0.02% mark at all powers and efficiency was over 98%. The four discrete gate drivers are clearly visible in centre field, and the circuitry on the right hand side is output overload monitoring.
This shows the first pcb version of the PowerDAC3 Stereo Power Module which incorporates two of the OPS circuits from the protos, each of which has its own SMPS voltage regulator. The OPS feature an adaptive 'calibration algorithm' which is used to electronically optimise output stage switch timing and so eliminate the effects of ageing and parameter spread in MOSFet switching. The average current mode SMPS switch at the PWM switching frequency of 352,8kHz and are rated at 60V 10A continuous. They have an analog control loop with digital adaptive loop control, digital reference generation and supervision. PWM values are sent to the modulator in the form of signed 8-bit numbers from an external host, via a synchronous LVDS data interface. The Power Module incorporates a low-jitter reference clock synthesiser and a stereo PWM modulator. Regulator control, system monitoring, self-tests, and OPS calibration and is via a synchromous LVDS control interface.
The Power Module consists of two pcbs, namely an upper power board and a lower control board. These are normally mounted in a stack with standoff pillars between the two boards and interconnection via headers and header sockets. In the photo taken last December the two boards are separated during debugging and testing for access to components, and the interconnections are made with ribbon cable harnesses. Testing is still in progress. (Jan 2008)
All logic and control of the OPS and SMPS regulators, conversion of analog parameters for calibration, PWM generation and control is implemented in a single Actel Fusion FPGA which can clearly seen on the control board. Only the SMPS control loop core is implemented in analog.
At Spes Infracta
Old 1st January 2008, 11:31 AM   #525
John Hope's Avatar
Default PowerDAC3
More pics. . .
At Spes Infracta
Old 1st January 2008, 11:37 AM   #526
John Hope's Avatar
Default PowerDAC3
More pics. . .
At Spes Infracta
Old 1st January 2008, 11:39 AM   #527
John Hope's Avatar
Default PowerDAC3
More pics. . .
At Spes Infracta
Old 1st January 2008, 11:41 AM   #528
John Hope's Avatar
Default PowerDAC3
More pics. . .
At Spes Infracta
Old 1st January 2008, 11:43 AM   #529
John Hope's Avatar
Default PowerDAC3
More pics. . .
This is the first pcb version being debugged and tested
. . .nearly finished now. .
At Spes Infracta
Old 1st January 2008, 11:45 AM   #530
John Hope's Avatar
Default PowerDAC3
. . . and this is Proto2.jpg that somehow got lost in the sequence.
That's all, folks. I'll take more pics of the pcb version when I'm done testing it in a few weeks. Months? Hell, I dunno - most of it's working so far!
Cheers
John
At Spes Infracta
Noise measurement amplifier - interested? jackinnj Solid State 15 27th March 2008 09:36 PM
New digital XO project borges Multi-Way 2 8th January 2008 06:49 PM
Copyright ©1999-2013 diyAudio
