Go Back   Home > Forums > Amplifiers > Class D
Old 10th April 2006, 02:06 PM   #1
Puffin is online now Puffin  United Kingdom
Default Soft Start for Sonic Impact
I have been looking at the "which toggle to use for Charlize soft start". I would like to incorporate a soft start into my S.I amp. The red switch leads are not polarised + & -. I assume therefore that it does not matter how they are connected to the switch. If I got an OFF, ON, ON switch would that be o.k and what is the best way to connect a resistor to get a soft start ? I assume the switch will have 3 terminals and (and as a novice at all this) would I be right in thinking that the resistor gets attached to one of the red leads only, or is it connected between the OFF and first ON position. Any help you can give would be greatly appreciated.
Old 10th April 2006, 02:13 PM   #2
Sorry, I forgot to say that it seems that it might be difficult to get hold of an OFF,ON,ON switch. I can get an ON, ON switch, would that do and so the same question applies as before, where do the connections go. Thanks.
Old 10th April 2006, 03:04 PM   #3
weng is offline weng  Philippines
Send a message via Yahoo to weng
dunno if a soft start (resistor type) will work with the sonic impact amp.
with the charlize, you can use a simple OFF-ON switch (spst) and put a resistor across. in OFF position the amp will be fed by the psu via the resistor (+/- 4v going to the amp) and when you flip the switch to ON it will by-pass the resistor feeding the amp direct from the psu at 12v. you need another switch though to cut the psu as it will feed the amp even in OFF position. in my case i have another switch that directly cuts the 220v going to the psu.
noob on the block
Old 11th April 2006, 12:13 PM   #4
Have any other of you electronic wizards got any suggestions ?
Old 11th April 2006, 02:04 PM   #5
cpemma is offline cpemma  United Kingdom
OFF-ON-ON may seem the "best" way but certainly with a submin toggle I find ON-OFF-ON is easier to manipulate and the switches are more common. With a plain SPDT (ON-ON) (or any manual soft-start, come to that) I'm not sure what effect leaving the amp on a strangled supply would have.
The resistor goes across the two 'ON' pins, a red lead to one of them, the other red to the common pin. Which pin depends on whether your convention is 'up for on' or 'down for on'.
Main value with the T-Amp will be to gently pre-charge the big stiffener cap you've added should your psu object.
Old 11th April 2006, 02:28 PM   #6
cpemma. Thanks for that. The way you have described the wiring up, is that for an ON-OFF-ON switch ? I seem to remember that panomaniac suggested this for the charlize. It means a quick up(or down) from the first ON position to FULL on (2nd on position) passing the OFF position.
I think ?
Old 11th April 2006, 03:21 PM   #7
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Thumpless turn-on mod for Tripath amps
I posted my soft start circuit a little while back and Michael showed us the one the Super-T amp uses. You can make either circuit on perf board for a few dollars in parts. You just need to give it power, ground, and run the soft start signal to the mute pin (after you lift or disconnect the mute pin from the circuit) and it will work every time you power up the amp.
Brian
Old 11th April 2006, 03:32 PM   #8
Thanks BWRX. However, I think it would be beyond my capabilities and a simple resistor solution as suggested by cpemma is far more to my liking. Do you have any comments on the resistor suggestion ?
Old 11th April 2006, 04:06 PM   #9
u can also refer to this thread regarding the function of spdt (ON-ON) and spst (OFF-ON) to use for the resistor based soft start config.
Which toggle to use for Charlize Soft Start
noob on the block
Old 11th April 2006, 04:35 PM   #10
I think ?
Correct, but resistor across the two 'ON' outputs with supply wire from the one chosen as 'Full ON' applies to any 3-position switch. I see RS do an SP ON-ON-ON min toggle that could be used as an OFF-ON-ON (with the first 'ON' not connected), 344-710 is the code and pin-out is on the page.
Soft Start Necessary? dtaylo3 Class D 2 26th December 2008 10:05 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 02:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 10:23 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 11:16 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 04:32 PM
Page generated in 0.11709 seconds (77.26% PHP - 22.74% MySQL) with 10 queries
