| Class D Switching Power Amplifiers and Power D/A conversion |
Today i received a Charlize, I have it set up with the SMPS PSU from Decibel Dungeon
My first query is about the 10000uF capacitor on the PSU outputs. I have fitted a cheap 'Jamicon' cap as its all I have . Is this capacitor necessary? And would there be a noticeable improvement from using a higher quality Panasonic for example?The second problem I have is with the 10 watt 10 ohm wire wound resister on the 5v rail. It is getting very hot, too hot to touch.. is it ok? Finally, I'm trying to decide weather to change the input caps tonite, or to wait until it is fully 'burnt' in. The caps are 2.2uf Obligatto. Thank You
#2 |
The Jamicon should be fine for this purpose. I see no reason to do away with it.
You would be better with a aluminium clad resistor with built in heatsink. I use 25w with no problems. I would leave the input caps till the amp is fully run in. Otherwise you will never know if the big Obbs are an improvement or not. http://www.rapidelectronics.co.uk/rk...0307&XPAGENO=1 |
#3 |
ahhh they look excellent
Is the 10k cap actually needed? If not i'll give it a listen without. |
#4 |
The power supply was connected the wrong way around on my charlize.
Is it repairable? |
#5 |
I'm very sorry for you, that's not fun and I can't answer your quenstion either. I have on for you though. There's some 50 posts covering topics about the Charlize. Couldn't you post about your wiring there?
#6 |
Sorry about that
![]() I already have replacement chips, i just need to know if thats all that should have died. And if it is i will take it to a profesional
#7 |
Hi Code,
How do your caps look? I'd worry about those, but being unfamiliar with that amp design I will defer to an expert if one pops up. I don't see a problem with posting about a blown up amp kit. A straight cap question may have been covered before in another thread. The search function is in the middle of the top right bar of buttons. -Chris |
#8 |
#9 |
I admit I'm too lasy to search but do you have a schematic or URL that points to it?
/Hugo |
#10 |
| SMPS questions | medogrizli | Power Supplies | 15 | 20th November 2007 12:24 PM |
| Charlize and SMPS for sale | peterphan | Swap Meet | 0 | 4th July 2007 06:18 PM |
| Building Charlize, two questions | lanierb | Class D | 6 | 15th December 2006 10:06 AM |
| Some questions froma super-newbie: charlize and monica2 | ExecutorElassus | Chip Amps | 0 | 18th April 2006 03:31 AM |
| SMPS questions | gaplessophile | Chip Amps | 5 | 4th April 2006 02:41 PM |
| Page generated in 0.11121 seconds (72.77% PHP - 27.23% MySQL) with 10 queries |
