Go Back   Home > Forums > Amplifiers > Class D
Old 26th April 2006, 07:15 PM   #41
zilog is offline zilog  Sweden
Just to contribute to the thread, here is a snapshot of Vgs of the lower side switch (between Vss and output), and the current in the sense resistor for the lower side switch when the amplifier is running idle. The polarity of this current is such that a negative voltage on the scope means that current flows from the load and into the lower voltage rail (Vss).
I cant really understand what is happening here, first the lower FET is active, but at the instant the switch opens there flows a current in the WRONG direction through the lower FET. Please help me understand this.
Old 27th April 2006, 12:22 AM   #42
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I'm currently facing similar issues. What you have to understand is that there are more things than just rail current showing up in your measurement
I use to feel like the small child in The Emperor's New Clothes tale
Old 27th April 2006, 03:41 AM   #43
Maybe I'm missing something, but I would expect the current to be a triangle wave centered about zero - just as shown in your photo (bearing in mind the fifty percent duty cycle of the sensed current). - a.s.
Old 27th April 2006, 01:05 PM   #44
The current is a triangle centered around zero - I have vertically readjusted both waveforms for clarity. What I want to show with this picture are the current spikes and their timing.
Old 27th April 2006, 01:50 PM   #45
At light loads, output timing depends only on the turn-off edges (turn-on edges occur post natural commutation) and the current spike direction is due to capacitive coupling (through Cgs) of the negative going edge of the turn-off drive (keep in mind that the way you have defined and displayed the current waveform is upside down from the bottom MOSFET's "point of view"). - a.s.
output FET overcurrent limiting zilog Class D 11 4th November 2005 12:14 PM
Audio Note DAC4 SRPP output stage problems! bbakota2000 Tubes / Valves 5 12th June 2005 12:25 AM
measuring amp output voltage emarald Solid State 1 5th April 2003 01:29 PM
Problems in Measuring 200mV in audio range (AC) r_s_dhar Everything Else 2 17th June 2002 05:01 PM
Page generated in 0.11774 seconds (58.61% PHP - 41.39% MySQL) with 11 queries
