| Class D Switching Power Amplifiers and Power D/A conversion |
I have a UcD amplifier built similar to a schematic I found on the net with standard configuration of the tail pair. As I understand, it should be possible to control the on/off state of the amplifier by letting the bottom end of the tail pair float or not compared to VSS. For my amplifier, this causes one of the output devices to switch at some frequency - and thereby pump the bus at an enormous rate.
Anyone else had this weird problem with an UcD? |
#2 |
Never mind, fixed it now - my implementation of the control pulled both emitter resistors and center resistor in the diff pair - the working version pulls only the center resistor.
| Novel current source: the Tail Lengthener | Sch3mat1c | Solid State | 1 | 12th January 2009 07:55 PM |
| if a power supply load is pulling 3A, does it means... | jarthel | Parts | 8 | 24th April 2007 01:58 PM |
| Nested feedback-modulating tail current idea | darkfenriz | Solid State | 2 | 25th October 2005 08:18 AM |
| Please Help - amp pop, shut down | bonz | Solid State | 1 | 1st May 2005 12:08 AM |
| Wrong tail current cause oscillation? | sam9 | Solid State | 5 | 11th June 2004 07:52 PM |
| Page generated in 0.07751 seconds (64.73% PHP - 35.27% MySQL) with 10 queries |
