| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
Yes, it was that thread.
#22 |
Banned
Well, it seems that I chose the worst combination for the regulated supply of my Class-D prototype input stage opamps: 6V8 zeners biased at 5mA (13uV noise).
The regulators are the typical NPN and PNP transistor configuration, whose bases go to the zener cathode (or anode for the negative rail, of course) and a series collector resistor to share power dissipation. A bias resistor goes from the HV rails to the zener cathode. This way I regulate the +/-50V rails to +/-6.3V. The zeners themselves are bypassed by a 100nF ceramic cap. Do you think that changing to a lower noise zener (such as 5V6 that shows 2.9uV at 5mA) will noticeable suppose a lower noise floor at the audio output? I use NE5532 input opamps. Thanks! |
#23 |
I don't understand what the fuss is about? The circuit below works very well, can be adjusted to cover most all situations and is a very cheap solution to boot. Upgrades would be to use single case matched pairs with the same current in both. This will give excellent results but is no longer as cheap. Of course the opposite sex is clearly possible.
This circuit with single case dual transistors will be better than using any other type of reference, including a band gap because it temperature tracks! Roger
Happiness is being owned by a cat |
#24 |
Banned
Here we are discussing (at least I think so) voltage regulators, not current sources, although the current source has appeared when Eva recalled the test someone did to measure various zeners and LEDs noise. That guy used a constant current source for his tests.
What I have mentioned is a typical voltage regulator based on BJT + zener reference. |
#25 |
Sorry guys, too many late nights, too little sleep! The proper circuit would include a LM431 with adjustment and the feedback taken after the pass transistor. This makes a very good regulator and is quiet, unfortunately not useful for negative voltages.
A variation is to use it as a closed loop reference to drive a LM317, 337 pair. This also works very well. In this case a pair of 431’s are required. The only trick of using the 431 successfully is to insure at least 10 ma through it and use a 10uf cap as local decoupling. The quality of this cap is of some importance as leakage will really upset things. Roger
#26 | |
#27 |
Congratulations, you pass the test! I was wondering if anyone would question this.
I have used the circuit successfully as the temperature range it sees in my application is rather small and a decrease is good. In using it to drive an output stage in line level circuits it compensates nicely for the outputs change. I don’t see an easy way to compensate it to track accurately. I was considering using a LM431 in place of the sense transistor with the adj pin used as the sense input. Of course the sense voltage would be a lot higher and would limit the maximum range a bit. In most applications I don’t see that as much of a problem. The reason I dropped it was because of the opposite sex problem with the 431. I sure wished they made a negative version! Any one up for simulating it and trying stuff? Roger
#28 |
I think I've got the answer to a nontemperature dependant current source. Throw a schottky in series with the current sense resistor.
Using LTSpice with the standard 3904 and 1N5819 models, a 10v supply and a 10k bias resistor. I used a 470 ohm current sense resistor with my new CCS and trimmed the other current sense resistor to equal currents at 20C (597 ohm). I then did a temp sweep 0-100C. Traditional Two Transistor CCS: Current@Temp 0C: 1.17095ma Current@Temp 100C: 0.817027ma Change: 30.225% My "New" CCS Current@Temp 0C: 1.10152ma Current@Temp 100C: 1.06516ma Change: 3.301% |
#29 |
Tim,
Good job! 3% is certainly close enough for government work. Giving up a schottky diode drop is not much of a sacrifice Roger
#30 |
Thanks. Being just a teenage hobbiest at the moment, it's very encouraging to hear such things from a more experience designer.
P.S. You don't even have to give up a schottky diode drop of usable range, the diode just drops voltage otherwise seen by the current sense resistor (see attachment). All you lose with this version is a dB or two of output impedance and 10 cents. |
| Bruno Putzeys in IEEE Spectrum | MartinRF | Class D | 11 | 9th March 2008 09:58 PM |
| Bryston's interpretation of a Bruno Putzeys article | mac | Class D | 5 | 24th October 2006 03:29 PM |
| What amplifier for reference? | lumanauw | Solid State | 44 | 17th April 2004 09:18 PM |
| Page generated in 0.11104 seconds (78.27% PHP - 21.73% MySQL) with 11 queries |
