Bruno Putzeys' reference UcD amplifier
Old 6th April 2006, 12:30 PM   #11
classd4sure is offline classd4sure  Canada
Account Disabled
Bruno Putzeys' reference UcD amplifier Send a message via AIM to classd4sure Send a message via MSN to classd4sure
But you can attach PDF here... if it's a problem for size or something feel free to email it to me as well.
Old 6th April 2006, 08:08 PM   #12
alfsch is offline alfsch  Germany
hi lenz,
kannst du mir den artikel auch senden?
alfsch at freenet.de
Old 7th April 2006, 09:53 AM   #13
anant_narayan is offline anant_narayan  India
LED's are used as a voltage reference. Combining with a transistor it forms a Constant current souce. This is a common scheme in any amplifier at the input stage where the compartor transistors need to be fed with a constant current source.
Old 7th April 2006, 10:33 AM   #14
lenz is offline lenz
Ooooh sh...
Is it the possibility.
I can`t separate the 5 pages from the 88 pages pdf document .
How to do?
Old 7th April 2006, 01:38 PM   #15
hmmm...
a: send pdf with all pages
b: try: http://www.cutepdf.com/Products/CutePDF/writer.asp
--> http://www.cutepdf.com/download/CuteWriter.exe
Old 7th April 2006, 05:17 PM   #16
Account Disabled
I think that's just one example of its use as a voltage reference.
What we should look at it is why it's possibly a better voltage reference than say, a zener for instance. Is it better than better than a proper reference as well? Or possibly just a quick and easy/cheap way of attaining a reasonable reference, without say resorting to band gaps etc.
Old 18th April 2006, 06:37 PM   #17
T0kiman is offline T0kiman  Belgium
If i'm not mistaking they wrote something about Bruno finding the zeners much to noise for the purpose they were used in. With this in mind i thought he must not be the only one thinking of this. I stumbled on an article of maxim where they use a zener as a white noise generator. The noise is created by the reverse breakdown process wich, for zeners with reverse voltages greater than 5.6V, is called avalanche breakdown. This is a random process of collisions of moving free carriers in the depletion region and fixed atoms. I can imagin that this process creates noise of some sort. I could be wrong to.
Also maybe a good question to ask is how much the zener voltage is dependent of temperature and power supply changes comparing to a normal led.
regards,
Thomas
Old 18th April 2006, 07:04 PM   #18
nilsomat is offline nilsomat  Germany
Lenz mailed me (thank you!) an article about LEDs as a constant current source. Since the article is in german and even though i am german i hardly understand it i probably shouldn't be the one to translate it here. I could post some (easy) schematics (but only next week) if anyone is interested.
Old 18th April 2006, 07:18 PM   #19
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Some time ago, somebody did quite extensive LED and Zener noise and impedance measurements and published the results in some forgotten thread. The author was quite shy at making conclusions, but his measurements clearly showed the zeners below 8v2 or 10V (I don't remember exactly) to be the noisy ones, and the zeners above 8v2 or 10V to perform much better than the equivalent string of leds both in terms of noise and impedance.
The results also suggested that some colours and sizes of LEDs are noisier than others.
Old 18th April 2006, 08:04 PM   #20
eva, you think of this..?
http://www.diyaudio.com/forums/showt...threadid=35821
Bruno Putzeys' reference UcD amplifierHide this!Advertise here!
Bruno Putzeys in IEEE Spectrum MartinRF Class D 11 9th March 2008 09:58 PM
Bryston's interpretation of a Bruno Putzeys article mac Class D 5 24th October 2006 03:29 PM
What amplifier for reference? lumanauw Solid State 44 17th April 2004 09:18 PM
