| Class D Switching Power Amplifiers and Power D/A conversion |
Hi , I am new here and I will need some help...javascript:smilie('
I would like to ask If anyone Knows where can I buy a Charlize assemble and a smps PC POWER . |
#2 |
As far as I know, nobody sells the Charlize already built. The power supplies you can find in many places including Amazon.
-Brad- |
#3 | |
Perhaps you can talk to Yeo at diyparadise.com. I believe he is might be able to help you on this.
![]() Quote:
#4 |
Huh?
The Charlize comes assembled, doesn't it?
Take the Speaker Voltage Test! |
#5 | |
#6 | |
diyAudio Moderator Emeritus
Brian |
#7 | |
I was thinking about an Amp 5 but after reading the posts decided against it. If Yeo came up with somthing similar "powerwise" to the Amp 5 that sounded as good as Charlize, he would get my money... again. Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#8 | |
Brian |
#9 | |
I wrote of support issues which would include persons that can follow the instructions and assemble the kits properly yet they do not work for whatever reason or they may may have questions. Andrew
#10 |
BWRX, it's that great big IF that worries me. I once was very good at soldering. My eyesight is reasonable, just the near focus problem that comes with middle age.
So, what equipment do I need to do smd properly and what sort of prior practice would you recommend? I was thinking of removing and replacing smds from old soundcards and seeing if they still worked. |
| FS: Audiodigit 2020 | diyHerb | Swap Meet | 5 | 8th February 2007 05:27 PM |
| Audiodigit/Autocostruire 2020 amp | Puffin | Class D | 1 | 4th July 2006 02:33 PM |
| Autocostruire Tripath 2020 Amp | mourip | Swap Meet | 2 | 1st July 2006 08:57 PM |
| Audiodigit/Autocosctruire 2020 amp | Puffin | Class D | 1 | 11th June 2006 11:13 AM |
| FS AudioDigit- 2020 T amp module | ianfromnotts | Swap Meet | 4 | 4th June 2006 06:54 PM |
| Page generated in 0.12385 seconds (80.02% PHP - 19.98% MySQL) with 10 queries |
