| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
diyAudio Moderator Emeritus
Well, the amp6 uses through hole components. It's the amp3 that uses almost completely surface mount parts.
As I've said before, I prefer to use a chisel tipped iron for soldering smds. The easiest way to do it is to put some flux on the pads with a flux pen, position the part with tweezers, get a little bit of solder on the iron tip, hold the part down with the tweezers, tack one side of the part down with the small amount of solder on the iron tip, solder the other side normally, then go back and do the first side if the joint isn't very good. The flux makes the solder flow better and more easily giving you nicer joints on the first try. It's harder to get good joints without flux but it can be done. All you can do to get better is practice. If you really can't see small stuff that well then a magnifying glass/light setup would be very beneficial.
Brian |
#12 | |
I recently killed three AMP1-B's and needed three new TA2022 chips. I emailed him about price, paypaled him the money, and received the chips all within a 4 day period. If that isn't good service I dont know what is. The prices of his kits are more than reasonable and he does a wonderful job packaging them. The AMP1-B's were my first electronics project of any kind let alone SMD work and I got all 3 amps together and working without a single problem, so an AMP3 or AMP6 should be cake. |
#13 |
I have middle age eyes, too and find simple magnifying reading glasses to be a big help. The stronger the lens, the nearer you can focus. I have a pair for general work, and a stronger pair for very close.
As for SMD, BWRX is young, clever and agile, he can handle it no worries. As for the likes of us, I suggest the AMP6 as it uses thru hole parts. Easy to build. Sounds great, too! Maybe I can post some tips on AMP6 building here or on the wiki or on my site. As I've built a few, there are things to be learned that will make the job easier, faster. Ahhhh... When I was young I used to build circuits between the pins of DIP ICs. We didn't have SMDs back then. Such great tiny stuff!
Take the Speaker Voltage Test! |
| FS: Audiodigit 2020 | diyHerb | Swap Meet | 5 | 8th February 2007 04:27 PM |
| Audiodigit/Autocostruire 2020 amp | Puffin | Class D | 1 | 4th July 2006 01:33 PM |
| Autocostruire Tripath 2020 Amp | mourip | Swap Meet | 2 | 1st July 2006 07:57 PM |
| Audiodigit/Autocosctruire 2020 amp | Puffin | Class D | 1 | 11th June 2006 10:13 AM |
| FS AudioDigit- 2020 T amp module | ianfromnotts | Swap Meet | 4 | 4th June 2006 05:54 PM |
| Page generated in 0.07300 seconds (73.11% PHP - 26.89% MySQL) with 10 queries |
