Go Back   Home > Forums > Amplifiers > Class D
Old 2nd April 2006, 09:56 AM   #1
vroum90 is offline vroum90  France
Default New classD amp: Gemincore of CL3
hello,
A new classD manufacturer: CL3 , a french society
They use a full bridge technology. Gemincore sound very well.
Take a look at www.Cl3.FR
@++ Seb
Old 2nd April 2006, 11:29 AM   #2
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
It seems inherently limited with that topology.
They ought to have answered the question of that not becomming more popular themselves.
Seems as though they've gone and patented the source follower? What's next.
Old 2nd April 2006, 02:09 PM   #3
They can't patent the source follower circuit as it's been around. The conclusion part of the paper does ask the question why people don't use it more often.
Koolkid
Old 2nd April 2006, 03:07 PM   #4
I just looked at Ambruschi US application dated Feb 2004.
Complementary totem pole has been used in class AB amps, including MOSFET output stage, and in many bipolar driver stages driving mosfet.
The question is what is new in CL3 circuit? The fact Ambruschi learned about its minimum shoot-thru doesn't make it new, only new to him.
Complementay totem poles have been around in the 70's at least, in bipolar output stage. Now isn't that obvious that mosfets can also be used instead of bipolar?
Koolkid
Old 2nd April 2006, 04:12 PM   #5
Account Disabled
Maybe it's the driver that would be "novel"? Seems that would be the trickier part with that kind of output stage?
Old 2nd April 2006, 05:39 PM   #6
CL3 did get a US patent. Whether it's enforceable is another issue.
No big deal. Pfet is more expensive. And there're better ways to switch a totem pole without shoot-thru current.
Koolkid
Old 2nd April 2006, 08:12 PM   #7
Account Disabled
Yeh, I still find it inherently limited, nothing special. The design is likely maxed out already.
Old 2nd April 2006, 10:15 PM   #8
sx881663's Avatar
Default Source follower?
If you think of this as just an impedance conversion then it looks to have some very real advantages. The drive can be simplified and optimized very nicely. The problems are exceeding the gate voltage when the output can’t track (shorted output) and the necessity of driving over the rail voltage to get full on at the rails. Also the fact that hi voltage “P” type device selection is very limited. These are the real stumbling blocks to this design. A transformer drive with a step up ratio would be an easy solution to some of the problems. This could also generate the oposite phase for bridge drive.
This could be the configuration of choice for lower power. Maybe up to 24 volts total? With proper design in a full bridge this could give well over 200 watts into 4 ohms. This would be enough for serious consideration I would think.
I will have to think about this a lot more.
Roger
Happiness is being owned by a cat
Old 2nd April 2006, 11:53 PM   #9
Account Disabled
heh heh.... can tell you're going after this! Right on. Xformer coupling is likely the simplest way and a good one I think.
Now what do you suppose they allude to when it comes to that 1000W burst power? PMPO?
Old 3rd April 2006, 03:12 AM   #10
sx881663's Avatar
Default Power?
Lets see, Distortion @ 10% (far into clipping) load at 2 ohms, 2ms burst and +3db to cover advertising claims and you have it. Don't even have to resort to peak power.
Roger
Am interested in ClassD LEIQINGU Introductions 2 9th November 2007 10:02 PM
New to ClassD DarkOne Class D 2 24th September 2006 05:11 PM
looking for classD follower lumanauw Class D 2 17th October 2005 01:54 AM
GC VS classD etalon90 Chip Amps 0 3rd November 2004 06:29 PM
Page generated in 0.10936 seconds (76.60% PHP - 23.40% MySQL) with 11 queries
