Go Back   Home > Forums > Amplifiers > Class D
Old 3rd April 2006, 06:35 AM   #31
sx881663's Avatar
Default More elegant?
Jaka,
Much less physical mass getting switched at HF, yes a more elegant solution. The +/- 12V power could be a very small SMPS and shielded. I like the way the drive is bootstrapped and limited so a shorted load wouldn’t destroy the outputs due to over voltage. An output inductor would limit the amount of switching current, hopefully. I would imagine the inductor would get quite toasty though.
I don't understand the use of the internal inductor and what it does best. It seems as though the driver would be working into essentially an open circuit at switching frequencies. Of course the 12 volt supply common would need to be referenced to the output, this is not shown.
Roger
Happiness is being owned by a cat
Old 3rd April 2006, 06:43 AM   #32
sx881663's Avatar
Default nh?
Jaka,
I think the drawing says nh not uh for the inductor value, is this correct? This makes a lot more sense. Just slows the transition slightly, right?
Roger
Old 3rd April 2006, 06:59 AM   #33
yes inductor is approx 400nH. It was 10turns on 2.5mm gapped toroid (approx .3mm gap).
Best regards,
Jaka Racman
Old 3rd April 2006, 08:49 AM   #34
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Originally posted by koolkid731
@ Workhorse: Like I said, IMO it's not patented nor patentable, because I know too many prior art source follower circuits, Jacman's is but one example but dated 2/2004. He got TWO source followers in a same schematic. 'nuf said. I already cited the 70's totem poles.
On the subject of patents, many are allowed only due to limitation of knowledge of patent examiners. Most patents are nothing more than a piece of paper on the wall.
I certainly don't worry a bit about any patent. They do however provide inspiration for better inventions.
Ah HAH! You see? What they've done is find a more elegant solution to the known source follower such as Jaka's obese dual follower arrangement..
"I certainly don't worry a bit about any patent."
Bold statement considering..
It'd be interesting to know just how many patents would be violated these days given the most basic class d implementation.
Old 4th April 2006, 02:44 AM   #35
Workhorse's Avatar
Send a message via Yahoo to Workhorse
KID , I already knew it , thats why i dont care about these damn patents!
K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 5th April 2006, 07:03 AM   #36
More ampliverter: US Pat # 7,015,754
Would be tough to implement such an impractical scheme.
http://patft.uspto.gov/netacgi/nph-P...=50&d=ptxt&S1=(330/251.CIOR.+or+330/251.CIXR.+or+330/251.CIUX,CIDX.)&OS=ccl/330/251&RS=CCL/330/251
Koolkid
Old 5th April 2006, 08:59 AM   #37
Account Disabled
Hi koolkid,
What is that you find impractical?
Here's a better link to it:
http://www.freepatentsonline.com/7015754.pdf
Given the caliber of it I'd question if they even got a prototype working.
Old 5th April 2006, 09:44 AM   #38
Come on, floating gate/base drive, series diodes, and a couple of even more serious issues.
That one won't work.
Koolkid
Am interested in ClassD LEIQINGU Introductions 2 9th November 2007 09:02 PM
New to ClassD DarkOne Class D 2 24th September 2006 04:11 PM
looking for classD follower lumanauw Class D 2 17th October 2005 12:54 AM
GC VS classD etalon90 Chip Amps 0 3rd November 2004 05:29 PM
Page generated in 0.11315 seconds (75.07% PHP - 24.93% MySQL) with 11 queries
