| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
If you are interested in finishing the amp for the Charlize, I strongly recommend you to by a digital multimeter. Those things can be had for cheap even at walmart 15 bucks?. It will help you double check connections, check polarity, and diagnose problems you may have. Also in the future, if you decide to do any other electronic projects, it will definitely come to good use.
I also recommend you check out the Tripath wiki if you haven't already. http://www.diyaudio.com/wiki/index.p...+Amplification Bgmicro, I believe also sells switching mode power supplies for 8 dollars or so. Good luck |
#12 |
I'm afraid Brent is about this. Most affordable adapters are not regulated and the output voltage will greatly depends on the load it is connected to.
I would suggest you used a better power supply that would bring out the best of Charlize.
| Yeo's Finished Charlize Amps...Build Quality?? | jdubs | Class D | 2 | 21st May 2006 09:27 PM |
| Some questions froma super-newbie: charlize and monica2 | ExecutorElassus | Chip Amps | 0 | 18th April 2006 02:31 AM |
| Extreme Newbie Question need help ? | audioaction | Parts | 2 | 25th May 2003 02:39 PM |
| Really, really extreme phono, more extreme than mine | peranders | Analogue Source | 34 | 22nd October 2002 11:59 PM |
| Extreme Newbie Question | KingsLaw | Solid State | 2 | 2nd December 2001 05:50 PM |
| Page generated in 0.06640 seconds (67.89% PHP - 32.11% MySQL) with 10 queries |
