| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
I once had a circuit idea for reducing charge current (specially at startup) with enlarged high-side storage caps. I have never tried it though.
You have the ubiquitous 100nF cap as usual. Additionally you have a larger one (the one for prolonged on periods of the high-side switch) that is connected to the main storage cap via a resistor in parallel with a diode. Dischargeing of the additional cap is done via the diode and chargeing via the resistor. Regards Charles |
#12 |
1.The 100nF cap you said , Is it mean the bootstrape cap??
2.So , I have to change my bootstrape cap to 100uF , maybe 220uF??? I still get some confuse , I will try it later. |
#13 |
Here is what I mean:
Regards Charles |
#14 | ||
Account Disabled
That's all fine, but doesn't begin to tell the complete story, or give a better explanation as to why his output stage falls apart at clipping. IR app notes calculate the minimal value required and don't tend to take into account 20% clipped at 20Hz. A click at turn on can be considered a secondary effect and could easily be delt with via other means than simply reducing the bootstrap cap value. Charles, that's a real neat idea and I think would be the easiest bandaide. |
#15 | |
#16 |
I try to change my bootstrape cap to 100uF.
But It can't turn on normally. I test the output of the error_amp is going to saturate. so , i change back to 1uF , It became working. does my C38 too small?? |
#17 |
titanchen68, hi
you again have mistake in yours sch. , like you cannot use same cap for startup delay on ir2110 and for power supply decoupling diode D5 is connected with its kathode to gate of one of upper mosfets insted to +rail (+55V) BTW my oppinion is to you need to use 10uF bootstrap cap (tantalum) and to keep 100ohm gate resistor and add some dead time at inputs of ir2110, just add appropriate RC part. Best regards Zeljko Kaiser |
#18 | |
2.have i need to add RC dead time control?? what is advantage for ?? |
| Best MOSFET for output stages | millwood | Solid State | 136 | 4th June 2010 07:54 AM |
| Class-A-Burn: an amp with capacitive feedback divider around MOSFET | Wavebourn | Solid State | 35 | 30th August 2009 07:41 AM |
| Mosfet burn | jegandren | Power Supplies | 2 | 24th July 2008 04:06 PM |
| mosfet output conversion | engel dela pena | Solid State | 15 | 13th October 2007 10:16 AM |
| Page generated in 0.13069 seconds (74.07% PHP - 25.93% MySQL) with 11 queries |
