Go Back   Home > Forums > Amplifiers > Class D
Old 12th March 2006, 07:57 PM   #11
In fact i am so impressed i will be selling my Linn Aktive based system... see Audiogon soon
Charlize strikes again.
Very nice work! I wish I could make something even half as good looking.
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 12th March 2006, 10:55 PM   #12
D0Hbert is offline D0Hbert  Philippines
I noticed you used 2 off-on switches for the soft-start circuit, how did you wire it? Thanks
Old 13th March 2006, 12:17 AM   #13
Neil,
Fantastic piece of work!
Old 13th March 2006, 02:33 PM   #14
neil_kaye's Avatar
vt4c... thanks for the kind workds and the lesson in ohm's law
DOHbert;
the two switches you see at the pack of the power supply unit are SPDT switches which are not true on-off rockers. Each switch has 3 pins- the cente for power in and the outer pins for the switched condtions.
Switch one was wired to live line in (pin 0-center), pin 2 was wired to live out and pin 3 was left empty.
Switch two was wired to theDC power out. Pin 0 (center) took the +ve 12VDC in., pin 2 to the soft start circuit, and pin 3 to the 12VDC out.
This way switch one controlled power on/off whilst switch two provided for the soft start switch.
Hope this helps
NAIM NAP 140 CLONE vs JLH 1996 Class A (30W per Channel (4ohm)) Melon Head Solid State 36 31st July 2008 09:54 AM
What class is a gainclone?! CJ900RR Chip Amps 10 30th April 2006 12:22 PM
new balanced gainclone - the Studio Clone mr_squeegs Chip Amps 0 28th April 2005 10:44 AM
Class A Gainclone bonsai171 Chip Amps 0 24th January 2005 02:34 AM
Clone of a gainclone ;) gigatron Chip Amps 19 27th July 2004 02:46 AM
Page generated in 0.07469 seconds (70.16% PHP - 29.84% MySQL) with 11 queries
