Go Back   Home > Forums > Amplifiers > Class D
Old 20th August 2007, 04:19 PM   #11
sovadk is offline sovadk  Denmark
sovadk's Avatar
That is not bad for an open-loop design. I can imagine that he used large bank of supply decoupling capacitors or a smps to overcome the distortion caused by supply pumping. I remember having read that 0.01% THD in a open-loop full-bridge requires a supply impedance below 5mohm. For a hal-bridge design the impedance has to be even lower.
Old 20th August 2007, 04:34 PM   #12
IVX is offline IVX  Russian Federation
IVX's Avatar
Yeah, they called it "Zero dead time switching", actually about 10nS into 20nS rise/fall edges. However Cirrus used ADC for tracking PSRR. You know, i can't find nothing about noise shaper in the tas5261.pdf..
Best regards,
E1.
Old 21st August 2007, 01:40 PM   #13
sovadk's Avatar
It says in the TAS5261 datasheet "t(low) Minimum low-state pulse duration per PWM frame, noise shaper enabled 50 ns". In other words is has a build in noise shaper which is active as long as the pulse width is above 50ns.
Old 21st August 2007, 05:05 PM   #14
IVX's Avatar
Sovadk, ok, but THD performance of the TAS5261, rather the same, not better vs old chips at least. It's strange..
Best regards,
E1.
FS: TI TAS5261 PurePath Power Stage - 75pcs theAnonymous1 Swap Meet 5 23rd October 2009 06:01 AM
Getting PurePath Studio GDE DoctorC Digital Source 3 26th August 2009 08:10 PM
Where to get PurePath Studio berni8k Digital Line Level 16 25th August 2009 03:37 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
TI Purepath percy Digital Source 0 14th March 2006 03:46 PM
Page generated in 0.07984 seconds (69.75% PHP - 30.25% MySQL) with 11 queries
