Old 10th March 2006, 04:40 PM   #1
percy is offline percy  United States
Default TI’s PurePath Digital™
Has anyone tried TI’s PurePath Digital™ chips ? I am asking about their "digital audio PWM processor" (TAS50XX) and "Digital Amplifier Power stage (TAS5111A, TAS5112A,..) lines of chips.
These pwm processors accept digital streams of a wide range of sample rates and sizes and they are meant to be paired with their digiital amplifier power stages for a solution that eliminates the dac entirely.
Has anyone tried these ? How do they compare (sound quality-wise) to other chips that are popular around here (Tripath/Hypex/Phillips/UcD...) ?
Besides TI who else in involved actively in such "dac-less" solutions ?
Old 10th March 2006, 09:32 PM   #2
alfsch is offline alfsch  Germany
wolfson has some pcm-pwm chips...
see: http://wolfsonmicro.com/products/WM8602/
Old 3rd April 2006, 10:51 AM   #3
shyfx is offline shyfx  Australia
I just found them on TI's website, looks extremely interesting and for the power junkies, they provide up to 100W/channel amplifiers!
Anyone tried them?
Old 3rd April 2006, 11:19 AM   #4
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
i've heard them in a 50w incarnation made by a friend of mine. Sounded fantastic (say 1-1,5 years ago?). Tact uses them too.
One feat they share with the ucd type amps is the (typically class d?) brilliant representation of highs (cymbals, crashes, hihats etc). Nice and smooth but *very* detailed.
Si fractum non sit, noli id reficere!
Old 20th August 2007, 02:39 PM   #5
sovadk is offline sovadk  Denmark
sovadk's Avatar
Hi
I've used them (TAS5111) in an analog setup with good results. The Purepath design are actually just a gate driver + mosfets + security circuits combined into one chip. They are designed for all digital solutions, but if you put a comparator an a couple of level shifters in front of a Purepath chip, you'll have everything you need to make a good sounding self-oscillating amplifier. Be aware though, that the new chips, tas5261 (300W) etc., shuts down if no pwm signal has been received for more than 17us. Given that the pwm frequency drops to zero at full modulation in a self-oscillating design, this might turn out to be a huge obstacle though. For analog clocked pwm designs this will not be a problem. I've attached a picture below showing how a clocked PWM modulator can be constructed, without the need for a noisy (and difficult to generate) triangle signal. This squarewave clocked PWM modulator is insensitive to clock noise and nonlinearity, because the square wave clock is feed into the feedback loop. For comparison, a triangle base modulator runs in open-loop, i.e. every imperfection in the triangle waveform distorts the audio signal and adds noise. The square wave clocked modulators is not only more simple, but also much better performing.
Old 20th August 2007, 02:41 PM   #6
sovadk's Avatar
Accathed is the Orcad files if anyone should be interested.
Old 20th August 2007, 03:44 PM   #7
sovadk's Avatar
You can see in the schematic below how I did the level-shifters, configured the TAS5111 IC and set up the self-oscillating hysteretic PWM modulator (U4A). The output filter is not intended for audio applications and the output feedback isn't shown. If you modify the output filter though by decreasing C8 and C9, you'll have a full working audio amplifier using that schematic.
About the clocked pwm modulator above. I've shown in the paper posted here http://www.diyaudio.com/forums/showt...threadid=90404 that the clocked design actually only has about 6dB less open-loop gain than a self-oscillating amplifier. In other words 0.005% of THD for a self-oscillating design, will turn into 0.01% THD for a sqare wave clocked design.
Old 20th August 2007, 03:50 PM   #8
IVX is offline IVX  Russian Federation
IVX's Avatar
Hi sovadk, i knew, that you'll comeback by this way. Indeed "digital" power stage is very convenient for analog class D design too, i've tried TDA8939 but it's an obsolete part unfortunately. Did you have any measurement of the real amp?
Best regards,
E1.
Old 20th August 2007, 03:55 PM   #9
sovadk's Avatar
I used it to drive a magnetic actuator with hall-sensor feedback, so no I can't provide any audio measurements. What I can tell you is that the principle works well and with the low dead time in a Purepath power stage, I would expect nothing else than good performance. A Purepath works well in an open-loop design (all digital solution) and I can only imagine that it would improve when an analog loop is added around it.
BTW. the new tas5261 actually has a build in noise shaper that corrects the error difference below 50ns between the reference PWM signal and the output PWM signal. This means that this all digital solution actuall isn't an open-loop design if I have to be strictley correct.
Old 20th August 2007, 04:09 PM   #10
IVX's Avatar
TDA8939 was simpler, just a power comparator, but in the open loop ref. design from Cirrus it gave .05%@20W if i remember correctly.
BTW, where is JohnW with its DAX1, which has similar noise shaper?
Best regards,
E1.
FS: TI TAS5261 PurePath Power Stage - 75pcs theAnonymous1 Swap Meet 6 8th February 2013 10:54 PM
Getting PurePath Studio GDE DoctorC Digital Source 3 26th August 2009 09:10 PM
Where to get PurePath Studio berni8k Digital Line Level 16 25th August 2009 04:37 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 27th November 2006 12:42 AM
TI Purepath percy Digital Source 0 14th March 2006 04:46 PM
Copyright ©1999-2017 diyAudio
