| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
I find in practice that having 2x4700uF power supply capacitance is sufficient to support 10Hz without adverse effects. Most people round here have much more than that in their supplies!
Where it makes sense to have some countermeasure is when using an SMPS that has all storage capacitance on the primary side. Many of these supplies don't even like having anything more than a few 100uF on the secondary side. In this case, pumping is a real issue. |
#12 |
I fully agree with Bruno (as almost ever)
You can see lots of SMPS's out there where output capacitance is ridiculous and the designers feel justified by just adding feedback (or conversely, they add only a few uF at the output because they are not able to make the feedback loop stable with more capacitance). |
#13 | |
Yes, a comment from my side. I actually never used the K6 SMPS supply with that 2x470uF, I modified the feedback loop and added more caps. Besides that, I also used the amps for the woofers in a kind of bridged way. Meaning, the left and right woofer channel sharing the same supply but I'm running both amps out of phase, so in most of the cases (at low frequencies), each amp will pump in the opposite direction. In the my final setup, I plan to use 2 amps for each channel to drive the two woofers per channel. Either in bridge or out of phase to avoid any risk of pumping. I know, I maybe overly cautious, anyway it won't hurt and hypex won't complain as they could sell me more modules that way :-) In your case with 6600uF per rail there should be no problem. Can't wait to check out your SMPS. Best regards Gertjan |
#14 | |
Hi Bruno, Seems like going balanced output would be a better choice than doing something like a load balancer? The pumping issue seems to be a mess for a off line switcher since it will go out of regulation unless you can suck current out of the UCD supplies. I'd think if sticking to single ended, that generating two loosly regulated outputs (perhaps clark converters for PFC) and then a sync buck regulator for each rail would be ideal. That's lots of stuff though. Seems like a balanced/bridged output would be a better cleaner solution. At any rate, I seems you need some way to store pumping energy and PFC might be a way. I look forward to seeing SMPS implementation that beats big iron though. Maybe you should just make a UCD that runs directly off the line! ;>) Mike |
| Smps | a2005r2003 | Power Supplies | 19 | 11th August 2011 06:19 AM |
| SMPS for B+ from PC PS | jkeny | Tubes / Valves | 1 | 10th February 2007 07:52 PM |
| Smps | Juani_12-5 | Car Audio | 8 | 20th January 2007 09:15 AM |
| Smps | rinox | Power Supplies | 0 | 2nd September 2005 10:05 PM |
| Need help on car SMPS | DFI | Car Audio | 16 | 18th June 2004 05:59 AM |
