| Class D Switching Power Amplifiers and Power D/A conversion |
Hello.
I like the concept of class D since heard from it but don't have the skills to understand it completly but I have a question for you. Is it praticly possible to alter a UcD module (or other class d) to make it's output voltage go trough the roof (for electrostatic speakers) It does not have to increase in Watts, but the voltage has to be 1kV minimum. And another problem is that electrostatic panels do normaly have a very low impedance. My inspiration that i would like to avoid the BIG trafo's that are used for this purpose and to drive electrostatic panels. Sorry for possible complete idiotness in this post! ![]() Greetings |
#2 | |
diyAudio Moderator Emeritus
Brian |
#3 |
Thanks a lot
The step up was something i'm trying to avoid but now i know that class d is not an option i'm going to investigate class a/d tube or mosfet designs. Greets! |
#4 |
That's a/b
| 845 Low voltage SE AMP | =maximum= | Tubes / Valves | 8 | 19th July 2007 10:56 AM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Rail Voltage to Capacitor Voltage | Mermprin | Parts | 6 | 20th September 2004 03:56 PM |
| secondary voltage vs. primary voltage | Stocker | Parts | 5 | 11th March 2004 07:41 PM |
| Rail voltage compared to transformer voltage | SteveG | Solid State | 4 | 22nd July 2002 11:50 PM |
| Page generated in 0.07803 seconds (75.23% PHP - 24.77% MySQL) with 10 queries |
