Go Back   Home > Forums > Amplifiers > Class D
Old 19th February 2006, 07:43 PM   #1
neil_kaye's Avatar
Default Wiring Charlize
I recently recieved a Charlize pre-wired. Everthing look sgreat except i am slightly confused about one thing.
Ther is a shielded cable that runs to the left adn right in, It terminates with 4 wires. Two coded white that go the left in and right in. Two yellow that appear to run straight from the grounds and atatched to the shielding. Ho woudl i wire this configuration to the RCA's (left and right on the free end) as only the two whites runt eh length of the cable.
Would i run two wires from the RCA grounds to the shielding or is there something i am missing here?
Old 20th February 2006, 12:11 AM   #2
Neil,
The shield wire should be connected to the RCA ground.
Charlize 2 dweekie Class D 72 25th September 2010 01:51 PM
Charlize, with or without a pre? zacster Class D 12 17th May 2007 02:08 AM
WTB: Charlize mrbigtube Swap Meet 0 25th June 2006 07:18 PM
WTB: Charlize JohnnyBoy Swap Meet 1 27th January 2006 03:34 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Page generated in 0.07327 seconds (68.35% PHP - 31.65% MySQL) with 10 queries
